RS turbo s1 track car - relay help required please
Old Aug 29, 2016 | 09:24 PM
fatty's Avatar
fatty
Default RS turbo s1 track car - relay help required please
Hello,
I have recently added a track prepped S1 to my collection and am having a bit of a headache with the fuel relay .
The original on melted the terminals inside which I managed to fix . The cars ran fine but the relay was still getting hot after the fix so I added a second relay to take the load etc.
Now the original relay is still getting hot :-/ and it's annoying me .
I've spent days checking wiring and earths etc. And although it is a bit messy under the dash it is sound so I'm left a bit baffled . I've checked the amp draw on the pump ( new ) and its around 8.3A on tick over and have changed the filter and checked for fuel blockages etc . Also changed the fuel pressure regulator .
The ignition switch wiring has 4 wires ( I think it's from a different model ) but is wired 'correctly' to the car side three pin connector .
One thing I have noticed is after starting the car ( position 3 ) and with the ignition back at key position 2 ( running ) the continuity between the live feed to the ignition barrel wiring and the wire in position 3 flicks on and off ? Surely it should be open after starting , could this be making the relay flick continuously and make it hot ? I can't hear anything .
If there's anyone that can tell me what voltages I should be seeing at the relay terminals I would be very grateful as its driving me insane .
Sorry for the lengthy post 🙁 Hope it makes sense .
Many thanks , Pete
Eigdoog
Mar 19, 2016 10:43 AM
Paul_RS
Mar 7, 2016 07:43 PM
delhump
Mar 7, 2016 10:07 AM
3dr cossie
Mar 7, 2016 05:23 AM
Tony2quick4u
Jan 21, 2010 02:55 PM
