Powerchips monitor
Hi has anyone got a manual / wiring diagram for a Colin's powerchips monitor. I've got it powered up using red =live
Blue= earth (which does power up ok)
And left with
White?
Yellow?
Thanks
And left with
White?
Yellow?
Thanks
The blue, white, yellow all need to go into the 3 pin diagnostic port.
If you look at the plug so it has two pins at the top and one in the bottom it is wired as such:
TOP LEFT________TOP RIGHT
YELLOW___________BLUE
_____BOTTOM CENTRE______
_________WHITE___________
Top man I'll give it go, I take it the blue is ground? As I wired red and blue to +&- just to check it works and lights up but obviously just get a NO COMUNICATION ON THE DISLAY.
I managed to buy one in kit form from collins when I say kit form it just needs mounting and switched wired and this was 2 years ago but I think they still have some and there better than any other monitor on the market
carbon1993
Aug 27, 2016 11:03 AM
cossirob
12
Aug 20, 2016 08:48 AM
