Fiesta 2014 Air Con drain
Hi, I have a 2014 Fiesta Titanium 1 litre econotec, the front carpets are wet and starting to smell, taking off the drivers side panel beside the centre console I can see that the evaporator is leaking clean water, presumably the condensate, but no apparent drain! There is a small stub with a cover and when this is removed water flows from it, but this doesn't have a drain tube attached, should it? No water apparent under the car as would be expected. Where should the condensate drain be?
Thanks
Adrian.
Thanks
Adrian.
no1fanofcolin
21
Apr 8, 2016 07:45 PM
paceo
Mar 23, 2016 05:28 PM
RSmark84
Feb 28, 2016 04:33 PM
