Some Cosworth parts
Old Aug 24, 2016 | 08:23 AM
Jasu's Avatar
Jasu
Default Some Cosworth parts
New parts / unused
- Setrab STD-SE-125 oil cooler 140€
- Group N quadrant ratchet 20€
- 90Ί water pipe under the radiator 4wd (AS) 40€
- 2wd water pipe (heating system - water pump) 30€
- RS500 Samco 76mm blue boost hoses + K&N filter with trumpet (hoses tested) 300€
- 864 Sachs mass plate 250€
- GGR header tank 300€
- valve cotters x32 (Cosworth) 70€
- valve spring retainer x16 (Cosworth) 40€
- valve spring platform x16 (Cosworth) 70€
- 4wd cam bearings (Burton) 25€
- LHD throttle cable (GGR) 45€
- 3dr remanufactured front indicators 70€
- 6151069 wiper stalk (newer model) 50€
- 6096586 3dr right front indicator 150€
- 6096588 3dr left front indicator 150€
- 6067427 number plate lights 50€
- 6118290 Lucas MK1 rear light gaskets 60€
- 6184648 ABS brake fluid reservoir cap 50€
- 6136177 rear wiper arm 20€
- 1583744 2wd water pump pulley 100€
- 6460817 4wd water pump pulley 100€
- 6112893 rear beam mount plates 30€
- 1640078 2wd rear brake plates 60€
- 1659225 4wd turbo heat shield foot 30€
- 6542403 2wd cambelt cover bolt 20€
- 6158072 aux pulley washer 20€
- 6103669 3dr rear anti roll bar links 100€
- 1492706 2wd clutch fork 50€
- 7042536 steering column rubber grommet 5€
- 6103875 3dr front indicator / fog lamp clips (spring) 30€
- 1656339 moonstone blue plastic sleeve body kit rivets x12 24€
- 6073718 rubber plugs x10 20€
- 5022701 2wd turbo damper repair kit 50€
- 6096616 3dr right side yellow fog light 150€
- 3dr bumper inside corner plastic brackets/clips 25€
- radiator fitting bolts 30€
- 3dr parcel shelf rubber straps 30€
- clutch and brake pedal rubbers 20€
The following are used:
- Bailey water swirl pot 80€
- Bailey power steering tank (new cap) 120€
- Bailey windscreen washer tank (with a new cap, pump and level sensor) 180€
- T25 distributor with new WPT-681 pigtail 250€
- 3dr / RS500 header tank 300€
- 4-spoke Motorsport steering wheel 120€
- Wolf Sierra Cosworth instrument panel (300 km/h - 10,000 rpm) 450€
Here some pictures.
Parts are in Finland.
Dispatch by mail.
The buyer pays the postage.
janikataja@msn.com or PM.
Old Aug 24, 2016 | 12:18 PM
shark91's Avatar
shark91
PM email for bailey
Old Aug 24, 2016 | 01:21 PM
3doorcozmess's Avatar
3doorcozmess
Shame the pound is not good against the euro
Chris 82
21
Sep 21, 2019 06:02 PM
RSmark84
Feb 28, 2016 04:33 PM
timb551
Oct 14, 2003 08:23 AM
fomoco90
Oct 10, 2003 12:02 PM
paul cox
Escort MK 5 / MK 6
42
Oct 4, 2003 02:04 PM
