Ford XR Parts For Sale Only Ford XR parts for sale in here please. Starting a topic requires you to have purchased a gold membership.
Fully Rosejointed rear suspension kit for Mk3/4 XR3i
Old Aug 16, 2016 | 11:33 AM
B16CVH's Avatar
B16CVH
Default Fully Rosejointed rear suspension kit for Mk3/4 XR3i
Having a big clear out.
Up for sale is a Brand New Fully Rose-jointed Adjustable Rear Suspension Kit for all Mk 3 & 4 Escorts
The kit replaces the two rear wishbones with adjustable bars that enable the toe and camber of the vehicle to be adjusted to create superb handling
Everything required is included within the kit. The Rose joints in this kit are the heavy duty kevlar lined versions not the cheap inferior versions.
PLEASE NOTE: You will need to run coil-overs to enable this kit to be installed due to the standard spring no longer being able to sit on the wishbone. Also note that if you have ABS load compensators fitted there will no longer be a mounting bracket as this is attached to the original wishbone, same goes for the anti roll bar connection but if you are using coilovers anyway you do not need to use this.
Bars are finished in tough gloss black powder coat.
Can ship abroad, please contact me for a price.
£375
Due to high PayPal charges i will only accept bank transfer
unless you want to pay PayPal fees (2.9%) or Gift it; (Please note: The postage charge is what i actually get charged, i do not make on postage £14.99).
RSmark84
Feb 28, 2016 04:33 PM
James Porter
Feb 22, 2016 10:42 AM
rizla
12
Nov 29, 2003 12:09 PM
timb551
Oct 14, 2003 08:23 AM
fomoco90
Oct 10, 2003 12:02 PM
