Ford Classics & Vintage Discuss all other Ford cars here, from the classics to Vintage to the Australian and American Fords!
MK2 Mex 'XE' Conversion Q
Old Apr 8, 2005 | 04:35 PM
fireandskill1's Avatar
fireandskill1
Default MK2 Mex 'XE' Conversion Q
Does anyone know of any info regarding putting the Vauxhall XE engine in a MK2 Escort? Any good reference sites?
A friend of mine has fitted one in his MK2 sorted all of the aftermarket bits needed for the conversion. but the electrics have proved a sticking point. It turns over and thats it.
He has kept the fuel injection system and distributer not carbs
Any info would be great.
Old Apr 10, 2005 | 06:46 PM
Steve Rowe's Avatar
Steve Rowe
try google mate hope thats some help
Old Apr 11, 2005 | 07:54 PM
xpackdave's Avatar
xpackdave
hello m8, i have an xe in my mk2.
runs a manta dizzy but i'm on carbs, if you want any pics let me know
dave
Old Apr 18, 2005 | 10:47 PM
Paul T's Avatar
Paul T
Hi - I've got a Mk 1, to which I fitted an Xe retaining Vauxhall fuel injection ( Motronic 2.8 - no dizzy ).
Any more info on the problem?
Fuel pressure?
Sparks?
History - Did it run?
Fault codes? - listed on the topbuzz site.
I found the following very helpfull :-
http://www.timandgail.pwp.blueyonder...t/vauxhall.htm
www.vaux-md.net/injection/( pages on testing the injection system)
http://www.topbuzz1.carenthusiasts.c.../gf50/gf50.htm
I used a Haynes manual for the wiring - quite straight forward and good fun when finished.
I'm just finishing of this winters project, now it has a Mini cooper supercharger and water injection fitted. It's running and should be on the road on May 1st, and in a ditch on May 2nd !
Good luck
Old Apr 21, 2005 | 05:03 PM
shed's Avatar
shed
http://www.valvers.com/tech_pages/20xe.htm
should be of some use for the wiring
ive done a corsa transplant in a couple of hours (god knows why it takes the "pros" a couple of weeks) as for the phsical stuff i would like to know for when i get arround to buying a mk1/2
Old Apr 21, 2005 | 05:16 PM
shed's Avatar
shed
Black - ignition switched live
blue - coolant temp
red/blue - fuel pump
green - rev counter
blue - coolant temp
black/red - starter
green/blue - oil pressure
black/yellow
brown - earth
black/white
blue/white - alternator
blue/green - oil pressure
Should get you running easy enough
Old Apr 21, 2005 | 07:17 PM
gazcos's Avatar
gazcos
Go to www.turbosport.co.uk You,ll find everything you need there !
Old May 14, 2005 | 08:16 PM
fireandskill1
Thanks for all the advice the car is now up and running. It dont stop as yet though!! bias pedal box needed, then it will be complete.
Old Jun 1, 2005 | 11:46 PM
Snowy_Astra's Avatar
Snowy_Astra
To get an XE running on the bare minimum you will need:
1) Black wire connected to switched live
2) Red wire to permanent live
3) Thick red wire with blue trace to fuel pump
4) Earths on the engine to bodywork
DON'T FORGET the earth for the engine, the ECU picks its earth up from the fuel rail where the black loom box sits.
The red + black (switched live) wires can be found on the right side of the loom just as it exits the black loom box
This might be of some help to you
P.s Nice choice on engine you won't be dissapointed
mk3ste
Oct 17, 2021 10:09 AM
Kiran1600E
11
Oct 2, 2015 11:35 AM
dalmarshall
Oct 1, 2015 06:46 PM
SMILER258
Sep 28, 2015 09:04 AM
Sp3no
Sep 27, 2015 07:23 PM
