Ford Focus ST225 (MK2) 2005-2010 Everything relating to the Mk2 ST225 preface & facelift versions from 2005 to 2010
2.5 missing/popping
Old Jul 15, 2016 | 08:16 AM
Kam B's Avatar
Kam B
Default 2.5 missing/popping
Mates focus 225 idles slightly rough not always from cold but it misses/pops on the same revs.
So when you put even slight revs on and let rev 2k it misses, then when you let off the pedal it goes pop pop pop. All at the same revs.
I thought vacuum leak perhaps? Could timing be off slightly?
Also, when you start the car from hot or cold it revs to 2k then drops to its normal idle speed.
On another issue the PAS pump whines, the liquid is black coloured - is the pump fooked or will a fluid change sort it?
Thanks
Old Jul 18, 2016 | 03:32 PM
A2KLAU's Avatar
A2KLAU
Interesting one this, sounds like its misfiring at 2k revs, it might be something to do with the map. Mine does the rev up to 2k on start up as well, but mine does have an unknown map on it when I bought it, so could be a case your mate's car is on a map..
As for the PAS fluid being black, its defo time for a change of fluid, my opinion is to do that sooner rather than later.
Old Jul 19, 2016 | 11:10 AM
Kam B's Avatar
Kam B
Cheers, its on a standard map - apparently its normal according to his owners club page on facebook...
Will change the PAS fluid then. Cheers for that
Old Jul 19, 2016 | 11:46 AM
A2KLAU's Avatar
A2KLAU
No worries
As for pops and bangs the ST is notorious for letting them off whenever it feels like it lol.
BIL N KEL
Apr 26, 2016 10:08 PM
MOD-GOD
Apr 11, 2016 06:40 PM
mrmann
Feb 28, 2016 08:47 PM
JamesS2RST
Nov 26, 2003 03:18 PM
Milko
Ford Escort RS Cosworth
Nov 24, 2003 02:35 PM
