hub bolt
Old Apr 8, 2005 | 10:30 AM
Rsailor's Avatar
Rsailor
Default hub bolt
can't get it off! it won't move at all, it will not turn to the left and I'm smacking it with a hammer. any ideas?
Old Apr 8, 2005 | 10:31 AM
Rsailor's Avatar
Rsailor
asap please.
Old Apr 8, 2005 | 11:41 AM
velocity's Avatar
velocity
which car, which side, front or rear,if a sapph coz which should the same as the escort coz and its the rear passenger side
its a left hand thread all others are right hand thread
Old Apr 8, 2005 | 12:32 PM
Rsailor's Avatar
Rsailor
cheers, got nut off now, don't know how to get the rest of it off. 97 rs2000 front drivers side
Old Apr 8, 2005 | 07:15 PM
Niall.b's Avatar
Niall.b
If u want to take the whole hub off u need to disconnect bottom wishbone ball joint, track rod end & bottom strut bolt as well as removing the caliper. If u just want to remove the driveshaft, bottom wishbone ball joint & trackrod ent , tap the shaft end out with a rubber or copper mallet & lift the hub assembly out of the way. Hope that is what u need.
Daniel Howard
Ford Classics & Vintage
Oct 3, 2015 10:44 PM
fordrallycar
Sep 30, 2015 07:57 PM
DavidK
Sep 27, 2015 02:55 PM
little bram
Sep 27, 2015 07:45 AM
