st170 tensioner bolt ??
Old May 11, 2016 | 11:31 AM
STeve's Avatar
Super Moderator
Default st170 tensioner bolt ??
When you look online at the ford timing belt kits they nearly all state includes new tensioner bolt finis 1117077 but ford no longer make this bolt so are NOT supplying it with tensioners or kits !, so are being sent out without it so they are either expecting you to refit your old one or source a alternate from somewhere, does no other bolt work as I was told the 2.0 normal zetec uses a same size bolt but has a part number of 4372415 so need info on this issue , cheers
daren5675
Mar 27, 2016 10:57 AM
Orion_Gav
Mar 15, 2016 03:50 PM
Danielbetty
Mar 14, 2016 10:55 AM
Mk3Ghia
Ford Focus ST
Mar 12, 2016 04:43 PM
pete-si
Mar 3, 2016 06:43 PM
