I have recently fitted a new loom into my series 2 and now have no Rev counter there is no power at the plug
Where does the Rev counter get a signal from? it was working before I fitted new loom
still no joy tested for broken wire all seems fine removed dials and tried 12 v direct onto Rev counter pins and it never moved any help or suggestions
Found the cause of the Rev counter not working a broken wire between the coil and where it goes into the fuse box traced fixed got the Rev counter working 👌
