Ford Focus (All Models) This forum is for discussion of all things pertaining to the Ford Focus Range that doesnt belong in the seperate ST & RS sections..
Activating cruise control on FF mk1,5 1,8 TDCI
Old May 7, 2016 | 05:55 PM
Atypoc's Avatar
Atypoc
Default Activating cruise control on FF mk1,5 1,8 TDCI
Hello, folks!
Recently I got all what is needed to install cruise control (steering wheel buttons, wires, etc.) and installed them. When I got to the last step, which is enabling cruise control on GEM and PCM modules through ForScan (I'm using ELM327 v1,5) I found all the options I can activate, except for the cruise control...
And the question is: How to get cruise control viewed the configuration window of both PCM and GEM modules?
I noticed that in the "configurate as built" section there's some sort of code. Maybe if someone can tell me what code should I insert, so I can have the cruise-control option showed in the configuration list...
Mine is Ford Focus mk 1,5 1,8 TDCI 2004
It has drive-by-wire accelerator pedal...
Last edited by Atypoc; May 7, 2016 at 05:58 PM. Reason: has to show more details about my car
Old May 2, 2017 | 07:41 PM
yairf's Avatar
yairf
Hi
I'm contemplating a similar project with my FF MK2.5 2.0L 16V. Could you please post some photos/description how you did yours ?
How did you resolve the activation issue ?
Cheers, Yair
VEEDUBBED
Mar 26, 2016 09:46 PM
capri-rs
Mar 14, 2016 01:30 PM
Danielbetty
Mar 14, 2016 10:55 AM
Vesty
Mar 4, 2016 05:43 PM
Rob Winstanley
Ford Focus Range
Mar 2, 2016 06:50 AM
