Ford Focus Diesel This forum is for discussion of all things pertaining to the Ford Focus Diesel Range.
Non start 1.8tdci 02 Ford Focus
Old Apr 24, 2016 | 07:24 PM
stormingthor's Avatar
stormingthor
Default Non start 1.8tdci 02 Ford Focus
Hi all,
First post on the forum, wondered if anyone could help me diagnose a diesel focus.
Car currently cranks but is not starting. Currently throwing p1200 code and low pressure and if repeated cranking then the glow plug light comes on and flashes. Fuel filter has been changed to rule out a blockage and metal fillings were found in the old fuel filter. Could metal indicate the pump has failed ?
I have tried quick start to no avail and car has new battery and recent glow plugs and fuel/oil filter but nothing has changed since the car was running.
Car has been serviced and lots of work has been done on the car. It has 130K on the clock.
Could anything else have been damaged at the same time?
Thanks in advance,
Ben
Old Apr 24, 2016 | 09:25 PM
H3lsing's Avatar
H3lsing
ffoc.co.uk
I remember reading that the fuel filter needs to have fuel in it or it won't start as there would be air in the system. That can cause the no crank no start.
simonmcf
Apr 1, 2016 05:50 PM
FORD RS MAD
Modellers Corner.
Apr 1, 2016 04:03 PM
Mar 31, 2016 08:26 PM
Acac
Mar 28, 2016 06:06 PM
VEEDUBBED
Mar 26, 2016 09:46 PM
