Choosing correct injectors
Hi I have an s1, currently running a 1900 Cvh, cam, 3" exhaust and a turbo systems chip
I'm gathering the parts to convert to ofam, as eventually once my engine has been tested to destruction I'd like to slap a zetec in and keep my management setup. Bit of forward thinking
Now I know the ofam requires high impedance injectors, and I'm trying to find some high impedance injectors that are matched to cossie greens
I don't want to buy injectors that limit me later but on other hand don't want too large injectors
Kinda narrowed it down to something like these
440cc
Static Flow Rate @ 43.5PSI : 42 lb/hr
12ohm impedance
The only bit that I'm unsure of is the spray come as these have split spray cone, will that make any difference??
I know these are fitted to beemers and Volvo so can be had cheap also
https://www.ebay.co.uk/ulk/itm/162044914833
440cc
12ohm impedance
JoeyBoyden
Mar 7, 2016 04:54 PM
