1.8cvh power
Old Feb 22, 2016 | 10:41 AM
MrEngineerdat's Avatar
MrEngineerdat
Default 1.8cvh power
Hi guys, i can appreciate the 1.8cvh was never known as a powerhouse, but i'm having trouble believing how the manufacturers could have released such a piece of shit to the market... Or is it just me, with this particular one? I know its meant to be ECO and not much fun in standard format, but I feel like driving it into a very thick brick wall at the moment and leaving it there.
Anyway, i have a sierra laser and the throttle responds like the police respond to someone robbing you. I really cant believe it, whatever i do to the mixtures it still responds tomorrow. Theres no air leaks. Connections and sensors are good. Timings not adjustable (apart from octane adjusting wire which has remained at 95 while i use 95fuel). The carbs been apart for cleaning and some time has been taken to assure the plug running colours are good (with correct plug gaps). And it still mugs me off every time i want to accellerate, causing me to use WOT regularly. It has a Pierburg 2E carb with different size chokes, which i dont like (i dont think this gives a progressive anything, its irritating especially on wet corners)
It pisses me off and if i cant fix it, im getting shot of it, simple; but i would like to have it do what i ask, as you would expect of any car. After all, even with running problems it aint bad on milage, but i cant see it lasting very long with regular WOT because of being the most un responsive car i ever drove.
Its only done 70k bless it, so it'd be good to keep it a standard runner if poss.
What might you suggest guys? Any help or advise if you know this setup already, would be amazing, and thanks in advance.
PS thoughts... I wondered if the primary choke jet wasnt working, giving me a lack of instant torque, but i was wrong, it works.
I wondered if the vacuum was eratic so fitted a guage, but from experience with this in the past, i'd say its behaving itself vacuum wise.
I wondered if the compression was down, but when tested its very good indeed.
Most annoying, as i feel im doing things right, but the car dont wanna know.
When driving (warmed up)
mecar > car > me > car > me > me and the missus > me and the missus afterward > so later on > and the car does this
Old Feb 24, 2016 | 09:55 AM
R4N SS's Avatar
R4N SS
i would bin that engine off and put a BOA 24v in there and i just so happen to have one for sale
Old Feb 24, 2016 | 10:42 AM
djmca's Avatar
djmca
Bring back old skool Ford
As far as tuning potential goes...... there is none! They were built for economy and nothing else. Way underpowered for a car of that size/weight.
You would spend twice the money of a full engine conversion to gain any extra power.
Your first mistake is trying to do anything with a Pierburg carb. They are complete cack!!
Stick a Weber on, they are a far superior carb to Pierburg, far easier worked with and will let the engine breathe easier which can only be a good thing.
Old Feb 24, 2016 | 01:24 PM
mk22door's Avatar
mk22door
Fart of the Purniture
A 2.0 Pinto sounds the best thing for it at the minute.
A 24v would make you smile but the parts list would be long and it's an involved job.
Pinto with Weber carb would be more practical by the sounds of it.
Exhaust & fuel run down the opposite sides of the car though I think, but shouldn't be too hard to sort.
I've had countless CVH Sierra's over the years and thoroughly hated every single one of them. (not the cars)
Old Feb 28, 2016 | 05:11 PM
steppy's Avatar
steppy
The 1.8 cvh is better used as a doorstop I've only ever drove one and it was terrible, all my sierra's have been pinto or twincam, the pinto idea from mk22door is a really good one, do you have a budget?
Bart
14
May 7, 2018 05:06 PM
2wdsaph ben
Jan 28, 2016 01:24 PM
SGP
Jan 28, 2016 10:24 AM
SGP
Jan 26, 2016 06:39 AM
Hamiltonleic
Jan 24, 2016 06:18 PM
