Focus st engine malfunction reduced acceleration
Old Apr 18, 2016 | 12:22 AM
mercer's Avatar
mercer
Default Focus st engine malfunction reduced acceleration
Hi guys,
I've recently been having problems with my car occasionally cutting out or starting with the above error mrsage, it also says power steering failure.
After restarting the car several times and revving a bit it comes back on.
When I get the error the car goes into limp mode and is about as fast as a tortoise.
I have recently replaced the battery and I had no problems for two whole days (Battery test said old battery was unstable), Then it just popped again randomly.
Any ideas? I've read about cluster failure which causes this, but I'm thinking loose connection as problem is intermittent and stopped for two days after a replacement battery.
Any help would be great as this is stressing me out big time.
Old Apr 18, 2016 | 06:27 AM
oldford's Avatar
oldford
I would start by having the fault codes read.
Old Apr 18, 2016 | 06:45 AM
RichieST's Avatar
RichieST
Is it the right battery? Must be a silver calcium, not your usual lead acid.
Old Apr 18, 2016 | 07:20 PM
mercer's Avatar
mercer
I've been told the fault codes can only be read when the light is on.
I'll check about silver calcium. I don't think it is tbh.
Thanks guys
Old Apr 19, 2016 | 05:36 AM
oldford's Avatar
oldford
You've been told wrong.
The fault codes will be saved for a period of time. They will not be removed until 40 engine starts without the problem.
Old Apr 19, 2016 | 08:35 AM
mercer's Avatar
mercer
Thanks for the info.
Car is in garage today. I checked the battery and it's a lead battery not silver calcium, so I've asked that to be changed.
I've also asked for fault code reader to be put on it and the power steering to be checked just for my peace of mind. I did check the steering fluid and it looked low.
Old Apr 19, 2016 | 11:21 AM
RichieST's Avatar
RichieST
They will throw a wobbly with the wrong battery as the smart charge system will not be able to charge the battery properly so definitely get the right one on there first and see what happens.
Old Apr 19, 2016 | 12:14 PM
mercer's Avatar
mercer
Could be that then as it starts fine just sometimes the error comes up randomly, probably once every 10 starts maybe? I can get the error off if I can rev the engine a bit before the warning chime comes on.
Old Apr 19, 2016 | 05:32 PM
RichieST's Avatar
RichieST
http://www.petercoopercarrepairs.co....t_charging.htm
Cold be worth a read of this, I bet it is your problem.
Old Apr 19, 2016 | 07:40 PM
mercer's Avatar
mercer
New battery is on. Code reader been on and picks up error code in cluster. Something about cad communication error or something, so looks like it's the cluster!
Old May 3, 2016 | 11:04 PM
mercer's Avatar
mercer
Had new battery and been fine for three weeks. Today the car went into limp mode as I was driving it. This car is stressing me out!
Old May 4, 2016 | 10:06 AM
STeve's Avatar
Super Moderator
thats the thing with electrical issues the come and go as they please, a replacement cluster is cheap enough and worth a punt as they do cause lots of issues like this, I have a few here if you decide to go that route with various mileages and I dont charge the earth
Old Aug 30, 2017 | 10:48 PM
Stuart Lee's Avatar
Stuart Lee
Did you get this issue resolved in the end and if so was it the cluster?
Old Sep 26, 2019 | 06:08 AM
dickemo's Avatar
dickemo
Default Electrical fault
I’ve read loads of things about this and it’s causing me pain.
2005 focus st keeps playing daft buggers. Sometimes the immobiliser won’t go off so I have to keep turning the ignition off, other times I get the engine warning, acceleration reduced lights. I also seem to have 2 different limp modes. I’ve had a fault reader on it and the only thing that came up was the lambs sensor fault to which I’ve ordered a new one.
i had a new battery on back in April and have heard that I need a silver calcium battery. The battery I’ve got is silver technology so I don’t even know if it’s the right one.
https://www.eurocarparts.com/ecp/c/F...f742cd6&000020
I’m saving for a wedding at the minute so don’t want to be going to an auto electrician to tell me he can’t define the fault along with a huge bill.
please help.
Old Sep 26, 2019 | 06:46 AM
oldford's Avatar
oldford
Yes, you need a silver-calcium battery. See: https://en.m.wikipedia.org/wiki/Silver_calcium_battery
Which fault code did you get? Exact fault text and.or number.
Old Sep 26, 2019 | 09:48 AM
dickemo's Avatar
dickemo
I’ll get it back on the reader at the weekend and get all the fault codes.
Old Sep 26, 2019 | 12:17 PM
RichieST's Avatar
RichieST
Immobiliser faults can usually be traced back to a faulty instrument cluster. Next time it plays up give the top of the dash a bang!
Old Oct 3, 2019 | 10:13 AM
dickemo's Avatar
dickemo
Default No joy
I put the fault finder on over the weekend and it came up with no faults. The car was running fine. I took it round the block and took it off and tried the ignition again and all the faults came on this time so switched it back off and once again the fault finder found nothing. Driving me up the wall.
one thing to mention though, I was driving about and the car went into full limp mode, 5mph all lights on, so I gave the binnacle a slap and it went into the reduced acceleration limp mode so it did make it a little better.
any clues out there?
Old Oct 3, 2019 | 10:35 AM
RichieST's Avatar
RichieST
Send the dash cluster off to ecutesting or another similar company to have it checked. I'm not saying it is definitely your issue, but it certainly sounds like it.
https://www.ecutesting.com/categorie...caAryxEALw_wcB
Macd
Ford Focus Diesel
Dec 2, 2019 11:23 AM
jasoft
May 5, 2016 06:24 PM
RsS2daz
May 3, 2016 05:19 AM
subhaan
Ford Focus ST
Apr 10, 2016 06:45 PM
manuel boeckx
Apr 10, 2016 12:35 PM
