How do you test the fuel pump on a 2wd saff, when I turn the ignition on the pump doesn't make a noise and if you put your hand on the pump you can feel a little movement and when you crank the engine over you can feel movement but it is silent are they supposed to make a noise?
The power wires to them can drop voltage with age, and thats why alternative looms are available. So put the full voltage on as your first check - as noted above
Does anyone have any things for me to check?
As suggested the old wiring loom could be dropping the voltage to the pump. If you can afford it, for peace of mind get a new fuel pump and a fuel pump wiring loom. If its still the original pump its pretty old now and probably worn out.
There was a thread on here a while back on this subject and some people were not happy with the non-genuine ones. I would rather pay a bit more and have the genuine Bosche one.
