Sierra cosworth carbon airbox lid or rs500 box??
Old Apr 15, 2016 | 05:51 PM
155lee's Avatar
155lee
Default Sierra cosworth carbon airbox lid or rs500 box??
On my saph and every saph I have owned before every 1 has had a k&n cone filter fitted.
I hate the way they look and they don't fit well at all in the space the standard airbox takes up.
Been looking around and seen this http://www.randbmotorsport.co.uk/sho...?ProductID=143
I quite like it and may buy 1 but is it going to flow enough for my t35?
You can also choose 60 and 65mm outlets,any advantage going bigger and using a one off hose to reduce it fir my turbo?
Also like the look of the rs500 airbox but finding a good 1 may be difficult.
Anybody running 1 or any experience of 1??
You're view would be appreciated.
Old Apr 15, 2016 | 10:56 PM
stevenr's Avatar
stevenr
Proper 500 airboxes don't come up very often and are changing hands at over Ł500 these days.I sold one last year and I couldn't believe it went up to Ł400 on ebay.
I've a Pipercross foam filter on mine and it seems to fit better than the big K&N so might be worth looking at different styles of filter maybe too?
Old Apr 16, 2016 | 06:57 AM
jason_nike's Avatar
jason_nike
Cant remember what the difference is between 500 and std Cosworth air boxes are, I know there is but it escapes me
Old Apr 16, 2016 | 09:43 AM
PAUL S's Avatar
PAUL S
The base of the box is the same for all versions of the sierra, its just the lid thats a bit deeper on the 500 version and a larger outlet for the hose. They all use the same standard filter. Unless you need one for an original 500 just go for the aftermarket lid, its nicer and saves a few pennies
Old Apr 16, 2016 | 09:52 AM
155lee's Avatar
155lee
Another question,what power level does the standard lid become restrictive?
Say including a quality k&n or foam panel filter???
Old Apr 16, 2016 | 08:37 PM
155lee's Avatar
155lee
Tried my standard airbox on tonight and I have a problem,the pace intercooler outlet directs the hose towards the airbox inlet,possibly the samco hose may need cut down a bit where it comes out if the turbo?
I much prefer the look and fit of the standard airbox over the cone filter so I want to make it work.
Old Apr 17, 2016 | 01:14 PM
Russ Payne's Avatar
Russ Payne
I run an rs500 air box on my t34 saph, roose did me a hose to fit
Old Apr 17, 2016 | 01:32 PM
155lee's Avatar
155lee
Did you bung up the breather connection in the lid?
My car has an aftermarket breather so if I refitted the airbox it won't get anything on it.
I like that airbox lid.
Wonder how many kids there actually are floating about?
Old Apr 17, 2016 | 01:57 PM
Russ Payne's Avatar
Russ Payne
No not yet, going for mapping next week so will do it before that, I like the standard look but had one in the garage so thought I would use it
Old Apr 17, 2016 | 02:01 PM
155lee's Avatar
155lee
Cool,if you find another drop me a p.m 😜
jim_robson
29
May 6, 2016 01:49 PM
RST83
Apr 30, 2016 04:38 PM
Tabbi
Apr 24, 2016 02:32 PM
R4N SS
25
Apr 21, 2016 01:38 PM
maxturbo
Apr 14, 2016 06:46 AM
