GT28 Series
Old Apr 12, 2016 | 10:35 PM
pduane's Avatar
pduane
Default GT28 Series
Hello all,
I'm currently running a CR T38.48 and looking for something with a bit more punch/less lag.
Aiming for around 400bhp and 400lbft
Basic spec as follows:
205 Block with standard head and cams
JE WRC pistons 9.2:1 CR
Asnu 600cc injectors
Omex 600
2WD exhaust manifold
Airtech 70mm inter cooler
Don't think I will head down the route of a GT30. I have been discussing with my tuner of using a GT28 and possibly fitting some cams with it. I have BD14 cams available.
Does anyone have a GT28 or GTX28 fitted and would they please share some spec and dyno sheet. Any help would be appreciated.
Thanks
Old Apr 13, 2016 | 03:05 PM
jontysafe's Avatar
jontysafe
You could struggle a bit with that CR, especially if you`ve got a skimmed head (most are)!
I would look at an efr6758 should be able to pick it up for about 1K now.
Old Apr 15, 2016 | 12:47 PM
R4N SS's Avatar
R4N SS
T34 0.63 will do what you need but it will be on its knees
Old Apr 16, 2016 | 12:47 PM
pduane's Avatar
pduane
Don't want to run t34 because as you say it will be on its knees. Also don't want to run massive boost, looking to only run around 1.5bar.
Old Apr 17, 2016 | 10:01 AM
DAN400's Avatar
DAN400
why not keep the t38 but change the ex housing to a 63?
tbh I ve never heard of a 38 run with a 48 ex housing before
Old Apr 18, 2016 | 09:06 AM
pduane's Avatar
pduane
I changed the housing to a .48 in a moment of madness in an effort to reduce lag!
Instead of changing back again I was looking at the GT28/GT30 route to upgrade from the T38 altogether. Even though the GT30 might not be that much better in terms of lag.?
I have BD14 cams available so might fit them with the T38 with a .63 housing and drive on from there.
Old Apr 18, 2016 | 12:40 PM
R4N SS's Avatar
R4N SS
I had a GT3076r and it was laggy as hell mate - not going down that route again
Old Apr 18, 2016 | 01:04 PM
pduane's Avatar
pduane
Yes, I don't think that A GT30 will suit me.
I would love to see dyno graphs for GT28's.
Old Apr 21, 2016 | 06:59 AM
cossynut2's Avatar
cossynut2
10 Year Member
A well sorted engine is capable of running 2bar boost all day long. We have chatted before and I would be sticking with the T38 with a 0.63 housing.
Old Apr 21, 2016 | 07:46 PM
2Litre's Avatar
2Litre
GT2871r 56 trim.
Perfect for your needs.
T.
Old Apr 21, 2016 | 07:54 PM
Caddyshack's Avatar
Caddyshack
Efr?.......
Old Apr 22, 2016 | 06:01 PM
pduane's Avatar
pduane
Default Erf
Efr?.......
Could a twin scroll ERF be made to work with the Yb 2Wd twinscroll exhaust manifold?
Old Apr 22, 2016 | 09:00 PM
costina's Avatar
costina
Live long and prosper!!
Yes.
I run a T34.48 stg 2 cutback blades
421bhp and over 400 lbft.
With 9:1 comp and a live map on a 63 housing would be great. And around your target figure. But with more than 1.5bar of boost.
I run about 36 peak holding 27ish.
Many different options out there a good mapper will make the difference.
Paul
Old Apr 22, 2016 | 09:07 PM
Staffi's Avatar
Staffi
Paul,
Do you drive your Cossie because how the fuck it's lasting at that power on a .48 housing amazes me
Old Apr 22, 2016 | 09:22 PM
costina's Avatar
costina
Originally Posted by Staffi
Paul,
Yep goes like fuck. I just set it up correctly..
As you know i am a fussy fucker....
I have a workmate with a Triumph daytona he could not get away from me after dropping 2 cogs.....
And thats was in 5th lol....
It will go bang but not from boost from old age.
Old Apr 26, 2016 | 03:47 PM
Bart's Avatar
Bart
I think the B1 frame efr should fit the standard manifold. You only have to change the flange to a t4.
7163 will make 500bhp and spool will be better then t34.
I will be using a 6758 twin scroll but have a tubular manifold.
Old Apr 26, 2016 | 08:53 PM
turbotrev's Avatar
turbotrev
When you say as laggy as hell what kinda revs are well talking where it made full boost out of interest?
Cheers Paul
cutch
May 2, 2016 05:55 PM
tockwell
Apr 13, 2016 11:24 AM
B13 JUS
Apr 12, 2016 08:12 AM
timsrs
Apr 10, 2016 08:15 PM
