No coolant circulating?
Old Apr 11, 2016 | 08:25 PM
daz-cos's Avatar
daz-cos
Default No coolant circulating?
Hi guys,
Right took my 2wd saph of the road about 2 years ago as wanting to save for an engine build, the engine still ran well it's just a little tired. Anyway I'm going to be moving house soon so need to get it roadworthy for the move. so fired it up today for first time since took it off the road and started on the button only problem is all the Coolant had disappeared, so topped it up but it's not circulating. My question is, is it a knackerd pump or could their be a nother reason as reluctant to change the pump as this would be part of the rebuild.
Thanx in advance
Daz
Old Apr 11, 2016 | 08:52 PM
Sierrasideways's Avatar
Sierrasideways
Blockage?
Old Apr 11, 2016 | 09:10 PM
daz-cos's Avatar
daz-cos
Possibly I'm going to stick a hose it it once I've dug it out the garage
Old Apr 11, 2016 | 09:22 PM
martysmartie's Avatar
martysmartie
It won't, due to the thermostat being closed.
Martin
Old Apr 11, 2016 | 09:39 PM
daz-cos's Avatar
daz-cos
I did think that but I'm sure normally there's a flow of coolant coming in to the header tank even from cold?, it has been a while though so I might be wrong, I'll let it get hot after I've flushed if n see what happens.
Cheers daz
Old Apr 11, 2016 | 10:15 PM
cossiestu's Avatar
cossiestu
If the coolant has leaked out, (id be initially worried where that's gone!?) is the water pump sized, or thermostat jammed shut?
Old Apr 12, 2016 | 06:15 AM
daz-cos's Avatar
daz-cos
No idea wher it went never noticed a pool underneath n when I topped it up it didn't leak? The pump spins so I presume it's not seized, dose the stat stop flow completely I thought it just cut flow through the rad? But I'll try all these things when I get time.
Thanx for the advice lads
Old Apr 12, 2016 | 01:03 PM
cossiestu's Avatar
cossiestu
I had a BMW that leake oil in the same way?! I meant, if it's a bit rusty inside, if the stat would be knackered, regardless of restrictions it may cause... Lol
Good luck with it, hope you get it sorted easily/cheaply!!
Old Apr 12, 2016 | 03:44 PM
daz-cos's Avatar
daz-cos
Ah ok well it never used water when it was on the road but it's been sat n not touched for 2 years so thought maybe it just evaporated if that's poss in a sealed system? I drained the water I put in and it did look pretty manky so stat maybe stuck, I'm not really fussed of its knackerd I just need to get it mot'd so I can move house and drive it to Nms without it blowing up
Old Apr 12, 2016 | 08:39 PM
martysmartie
That is the return from the turbo, which should still circulate.
Martin
Old Apr 13, 2016 | 07:08 PM
daz-cos's Avatar
daz-cos
Well put a hose down it tonight and turns out the turbo feed was blocked, so stripped and cleaned all the hoses and all is well. Thanx for the help guys
Daz
Tabbi
Mar 25, 2016 08:19 PM
paceo
Mar 23, 2016 05:28 PM
Tabbi
Mar 23, 2016 10:17 AM
27
Mar 23, 2016 06:52 AM
PhoneShopRS
Mar 23, 2016 01:20 AM
