quick question
Old Apr 9, 2016 | 07:08 PM
cozzy jeff's Avatar
cozzy jeff
Default quick question
so driving the 150 miles home from norris motorsport today the coolant temperature was around 72 degrees,i think I have a 82 degree thermostat in the car am I right in saying mine wouldn't have opened?
do I need a lower rated one as I was getting very little heat through the air vents.
Old Apr 10, 2016 | 08:07 AM
manuel boeckx's Avatar
manuel boeckx
I think Your thermostat was opening To soon. Normally the thermostat blocks the radiator below his temp reading. You can check the thermostat by feeling on the radiator hose, This should be cold below the thermostat reading. If you feel hot water At 60 degree It's already open then. Grtz
london_chris
Apr 14, 2016 08:42 PM
RichieST
29
Apr 10, 2016 04:38 PM
Indyrs
Apr 7, 2016 09:53 PM
Simon78
Apr 6, 2016 08:42 PM
xr2john
Apr 3, 2016 08:05 PM
