What clutch for setup??
Old Mar 29, 2016 | 04:59 PM
A.t.p's Avatar
A.t.p
Default What clutch for setup??
I recently wrote a topic asking what intercooler and clutch i should get for my standard ERST S2.
There have been a little change in setup, so i was wondering if the AP Racing organic clutch CP 2000-15 this one:
http://www.demon-tweeks.co.uk/performance/clutch-kits/car/ford/escort-mk4-rs-turbo/a-p-racing-performance-formula-clutch-kit-organic-220mm-torque-cap-192nm-142-lb-ft
Would be enough for this setup?
-31 cossie actuator
Airtec front Mount intercooler.
And a stage 2 turbo.
And what power Can i get from this?
Old Mar 29, 2016 | 06:41 PM
Chopshop85's Avatar
Chopshop85
I had the 230nm - 169lb ft AP clutch. That actually started to slip around 195Ft Lbs on the dyno. So I would imagine you'll get a bit more than the 142Lb ft out of the clutch you linked.
Old Mar 29, 2016 | 07:17 PM
A.t.p's Avatar
A.t.p
So you would suggest a more powerfull clutch, for my setup?
Old Mar 29, 2016 | 07:54 PM
Chopshop85's Avatar
Chopshop85
It depends what power you want/make. If you are going for whatever the engine can make then it might be worth while buying the best clutch you can for future power etc.
Also I run a hydraulic clutch set up so I can't comment on how heavy these clutches get.
Hopefully someone can give you a bit more info.
Old Apr 1, 2016 | 03:23 PM
Karl @ FPT's Avatar
Karl @ FPT
Always a pleasure!
A stage 2 T3 (.36/50) will do around 230bhp and a bit less torque so no that clutch will not be enough, the CP2000-8 is what you need mate.
Old Apr 2, 2016 | 10:09 AM
A.t.p's Avatar
A.t.p
Great, thanks!
But i can't Seem to find the cp 2000-8 only the cp 2000-35 but i guess that's just as good, or even better?
ConnollyGT30
Mar 30, 2016 04:55 PM
VEEDUBBED
Mar 26, 2016 09:46 PM
plumberdave
Mar 26, 2016 06:54 PM
RS_Gav
15
Mar 26, 2016 04:52 PM
Tabbi
Mar 25, 2016 08:18 PM
