Is a Sierra 2.0 injection fuel tank same as cosworth fuel tank?
Old Mar 20, 2016 | 11:31 AM
timotei1980's Avatar
timotei1980
Default Is a Sierra 2.0 injection fuel tank same as cosworth fuel tank?
Hi,
as per title, is a Sierra 2.0 injection fuel tank the same as a cosworth fuel tank with the internal swirl pot, outlets etc?
Old Mar 20, 2016 | 12:13 PM
ajamesc's Avatar
ajamesc
cossie fan (unluckerly)
The original cosworth tank has a large plastic swirl pot set up inside it. I'd be carful fitting other tanks as I did and ended up with massive surge issues but mine was modded a fair bit
Old Mar 20, 2016 | 12:53 PM
timotei1980
Thanks.
I've currently got a pattern part fitted with internal fuel pot (metal) but still had surge when running under 1/3 of a tank on track so was wondering if the 2.0 inj tank was the same as the cosworth original with the better plastic swirl pot.
Old Mar 20, 2016 | 01:55 PM
ajamesc's Avatar
ajamesc
Originally Posted by timotei1980
Thanks.
I never had a single surge issue with the original tank at 500bhp. I got a pattern one with a metal swirl pot had it converted to aero fittings put it in the car when I changed my fuel lines and it surged like fuck. Had to fit a swirl pot and second pump
Old Mar 20, 2016 | 02:00 PM
costina's Avatar
costina
Live long and prosper!!
Those aftermarket tanks are poo.
The sierra injection tank is the same only if it has a external fuel pump.
So to be sure if its a injected pinto tank its the same along with early xr4x4 and 4i.
Old Apr 1, 2016 | 06:50 PM
Cosnada's Avatar
Cosnada
Same as
Old Apr 7, 2016 | 10:49 AM
R4N SS's Avatar
R4N SS
I put a new aftermarket tank on my old 3dr and it was fine. You need to make sure its the same as the xr4i - no issues on track either
Adam-M
Apr 22, 2016 09:00 PM
cossie09
11
Mar 26, 2016 06:32 PM
Cosnada
Mar 14, 2016 06:46 PM
2Litre
Mar 14, 2016 09:57 AM
Will Pedley Racing
Mar 13, 2016 10:09 PM
