Who can fix my Mondeo?
Old Feb 25, 2016 | 04:48 PM
Billy_RS's Avatar
Billy_RS
Default Who can fix my Mondeo?
So apparently my daily (MK3 ST TDCi) Mondeo needs a new diesel pump. Ford wanted about £3500 to fix said problem and I said "ha!"
Turns out, not many garages want to get involved with this job. I'm at the point where the car keeps going into limp mode under acceleration making overtaking etc dangerous with the coil symbol flashing. Once I turn the ignition off, wait 30 seconds, start the car it's back to normal. No eml light.
Anywho.... Anybody had same experience or more importantly, could point me in the direction of a capable garage that won't take the piss like ford?
Cheers,
Billy
Old Feb 25, 2016 | 04:52 PM
xr_craig's Avatar
xr_craig
Cheers,
Billy
No idea how far it is from you but sure start in Doncaster sorted my mates. Not sure how much it cost him though.
Old Feb 25, 2016 | 05:08 PM
Billy_RS's Avatar
Billy_RS
Thanks mate, but Doncaster is a bit too far for me.
Old Feb 25, 2016 | 05:19 PM
doga-ot's Avatar
doga-ot
Its because the pump has to be programmed to ecu to work same as injectors if you change them on new fords
Old Feb 25, 2016 | 05:23 PM
doga-ot's Avatar
doga-ot
Also my old man had same issues with going into limp mode under hard acceleratio./overtaking etc then ok again once easing off switching car off his was 1.5 tdci megane 07 plate his was badly blocked egr we cleaned and blanked and egr delete all was ok after
Old Feb 25, 2016 | 05:33 PM
Billy_RS's Avatar
Billy_RS
Cheers mate, I have had the egr cleaned out before, but might try it again or block it off?
Old Feb 25, 2016 | 05:51 PM
If i remember rightly there should be a round plastic cover on tue timing chain cover where the pump is. Im sure you can get a tool to hold the pump pulley and chain in place for when moving the pump.
Old Feb 25, 2016 | 06:03 PM
Gazzonator's Avatar
Gazzonator
Gary Krishna
Try Bennetts in Watford Billy, they're diesel specialists and I have known some main dealers to take cars to them to sort out
Old Feb 25, 2016 | 06:15 PM
london_chris's Avatar
london_chris
first diesel in croydon
Old Feb 25, 2016 | 06:24 PM
Billy_RS's Avatar
Billy_RS
Cheers Guys
I'll start ringing around in the morning.
Old Feb 25, 2016 | 06:32 PM
Good luck.
Old Feb 25, 2016 | 07:31 PM
Fudgey's Avatar
Fudgey
Baby Cheesus
Mates just had the pump go on his 58 reg mondeo, cost him £900 to sort but took the garage a couple of weeks.
He is in worcester so a bit far from you
Old Feb 25, 2016 | 08:10 PM
cge's Avatar
cge
Mine was doing the same thing mate, plugged it in and it said egr so bought a new 1 and no change. I decided to go for injectors as they are the same as the 130bhp engine so can be bought cheap which cured the problem.
Got to be worth a go before swapping the pump.
Chris
Old Feb 25, 2016 | 08:14 PM
Billy_RS's Avatar
Billy_RS
Chris
Only thing is mate, i just want it fixed and if i do injectors first and it doesn't sort the problem then I'm going to be digging myself an even deeper hole.
Times like this i wonder why i ever thought of buying a diesel
First and last
Old Feb 25, 2016 | 08:17 PM
BRAM's Avatar
BRAM
I would be asking someone to do a injector leak off test, it sounds like you have a injector or injectors away.
Old Feb 25, 2016 | 08:22 PM
Billy_RS's Avatar
Billy_RS
Apparently Ford did that..... But i don't believe them
Old Feb 25, 2016 | 08:40 PM
The Youth.'s Avatar
The Youth.
have you changed the egr valve and have you had any codes read?
I changed the pump on my st tdci in 2014 after the pump failed, this caused an injector or 2 to stick wide open it nearly hydraulic'd the engine but I switched it off in time!
I had a spare pump that was stripped and cleaned rebuilt by a diesel specialist (I used flavells in Thornaby near me http://www.taflavell.co.uk ) they also lent me the special tool to change the pump this must be used
jack up engine and remove engine mount
remove inlet manifold and egr valve
remove round plastic cover from chain cover
release fuel pipes and wiring from pump
remove rear bracket from pump
crack off 3 bolts from between pulley onto pump(through the round hole)
fit locking tool to front cover
totally undo 3 bolts then remove pump
refit is reverse lol
you must then check the fuel filter for metal particles if metal found then you have to clean out all the fuel inlet pipework (ultrasonic is best)
drain tank then remove tank and fully clean out
refit tank and fit new filter
injectors must then be stripped and cleaned by specialists flavells can do this, they did mine
good luck if doing it yourself I did and it was fine
steve
Old Feb 25, 2016 | 08:58 PM
burnzy's Avatar
burnzy
burnzy
The youth has got it down to a T it's all the advice I would of given, it doesn't need coding, that's the older tddi engines iirc.
Old Feb 25, 2016 | 09:03 PM
Billy_RS's Avatar
Billy_RS
I won't be doing it myself, but thanks for the guide all the same.
I'll start with the egr first see if that makes a difference.
Then ill get on to a diesel specialist who know what they doing.
Cheers everyone
Old Feb 25, 2016 | 09:35 PM
DangerousBryan's Avatar
DangerousBryan
The pumps aren't bad to do at all,and don't need programming.but,and it's a big but. I have only changed one in 11 years at a Ford dealer,and that's only because it was leaking. Injectors are far more common.
Old Feb 26, 2016 | 07:09 AM
James Porter's Avatar
James Porter
To be honest though mate that's probably due to how much they charge to do a pump!
Old Feb 26, 2016 | 07:50 AM
Billy i fookin hate diesesels.
I doubt i will ever own one.
Ive changed a few egr valves on transit tdcis. Of there the same as a mondeo there ok to do.
What i do to get the gasket in place is to get 2 bolts and cut them down and make them into studs. Then fit the gasket and the valve.
parso316
Ford Mondeo Including ST
Apr 1, 2018 11:25 AM
RSricRS
Feb 1, 2016 08:29 PM
evoboy
Feb 1, 2016 08:21 PM
ford addict
Jan 31, 2016 05:19 PM
Rustler
Escort MK 5 / MK 6
Jan 29, 2016 09:23 AM
