2003 st 170
Old Feb 24, 2016 | 09:44 AM
Rickyst's Avatar
Rickyst
Default 2003 st 170
I need help pls anyone!!! I'm going to do a head gasket on my car which comes as a whole set but I can't get a manual to guide me through it like taking parts off like cambelt etc so if anyone could help like a link to click on or anything pls post back 😀
Old Feb 24, 2016 | 10:23 AM
R4N SS's Avatar
R4N SS
Haynes manual mate
Old Feb 24, 2016 | 10:39 AM
Good luck matey. I dont know if it will be easier taking the inlet manifold off with the head or take it off before you remove the head.
There isnt much room down there. I would take the exhaust manifold off and leave that on the car.
Old Feb 24, 2016 | 01:05 PM
STeve's Avatar
Super Moderator
only manual covering the engine is the US version svt, asking for a how to on doing this would be like asking someone to write a novel
Old Feb 28, 2016 | 03:16 PM
rhinopower's Avatar
rhinopower
If you need chapter and verse instructions to do it, you shouldn't be doing it. It's just like every other zetec
Old Feb 28, 2016 | 05:25 PM
Pf-Lee's Avatar
Pf-Lee
Spot on as above
Old Mar 8, 2016 | 12:50 PM
Rickyst's Avatar
Rickyst
Right so peeps please help I've done the had gasket new plugs serviced etc etc.. It's all back together but runs lumpy on idle and it's all pointing to air n fuel now any suggestions please as I'm losing faith ����
Old Mar 8, 2016 | 03:56 PM
STeve's Avatar
Super Moderator
try changing coil pack as one of the most common reasons for poor running on the 170
Old Mar 8, 2016 | 05:32 PM
botters's Avatar
botters
competant bodger
is the engine timed correctly
Old Mar 8, 2016 | 05:46 PM
rhinopower's Avatar
rhinopower
Probably not! Cam timing or a breather hose etc is left off.
Old Mar 9, 2016 | 04:46 PM
Rickyst's Avatar
Rickyst
All hoses are back on connected cams timed up as taken apart with like marks etc new coil pack done ??
cossynut2
28
Nov 8, 2019 07:25 PM
minder
Ford Focus RS Parts for Sale.
Apr 3, 2016 03:47 PM
3doorcozmess
Feb 22, 2016 08:10 PM
Luca
Feb 21, 2016 12:33 PM
Piston Broke
Feb 18, 2016 09:28 PM
