Cosworth Not Starting...
Old Feb 15, 2016 | 06:25 AM
SmudgerByName's Avatar
SmudgerByName
Ford Fanatic
Default Cosworth Not Starting...
Right Guys. Need some help,
On Thursday the Car wouldn't start. For love nor money the thing was turning over. Even jump starting wouldn't get it going so I went and bought a new Battery. Upon changing the Battery the car STILL wouldn't start so I went and checked the usual... Plugs, Leads, Dizzi Cap etc to find that the HT Lead to the Dizzi was badly corroded and had snapped of into the Cap. So New Leads, Plugs and Dizzi Cap were ordered and promptly fitted Yesterday. Car still isn't firing up though. I was running fine on Tuesday/Wednesday so I'm stumped now. Only thing I can think of it that since I've changed the Battery it's something to do with the Immobilizer... Any ideas? Or anyone local to Birmingham??
Old Feb 15, 2016 | 06:31 AM
MARKYMARKONE's Avatar
MARKYMARKONE
Hi
Mine done simular to this years ok and turned out to be the phase sensor in the distributor
Old Feb 15, 2016 | 07:43 AM
155lee's Avatar
155lee
Is it sparking?
Is the fuel pump buzzing?
If it's the pump try the fuel cut off reset under the spare wheel.
No spark at the plugs fit a plug into the main ht lead,if that's sparking then check the phase sensor/firing order.
Old Feb 15, 2016 | 07:47 AM
SmudgerByName
Ford Fanatic
Originally Posted by 155lee
Is it sparking?
Right, It is Sparking and the Firing Order is Correct. Fuel Pump is Buzzing so I know it isn't an issue with that. I am looking at the Phase Sensor as a Possible Problem but I'm thinking it might be an Immobilizer Issue Potentially as well. It was running fine prior to Changing the "Flat Battery"
Old Feb 15, 2016 | 07:48 AM
SmudgerByName
Ford Fanatic
Originally Posted by MARKYMARKONE
Hi
I've ordered a Phase Sensor just in case mate since you aren't the first person to mention this
Old Feb 15, 2016 | 07:55 AM
cossynut2's Avatar
cossynut2
10 Year Member
Immobiliser would be my main suspect.Sometimes changing the battery can affect them. Get a mobile auto electrician to come and check it out. I had this happen on my 1990 2wd years back.
Old Feb 15, 2016 | 07:58 AM
SmudgerByName
Ford Fanatic
That is what I am thinking mate. Gonna give Breakdown Cover a Call when I'm home from work see if they can pick something up
Old Feb 15, 2016 | 06:31 PM
SmudgerByName
Ford Fanatic
Quick Update Guys... Cars running. Thanx for all the advice. Ended up being some poor wiring to the Fuel Pump. That hass been amended and runs like a dream now
Old Feb 18, 2016 | 02:53 PM
cossynut2's Avatar
cossynut2
10 Year Member
Glad you got it sorted out. Remember the wiring is getting old so a lot of owners get new engine , fans and fuel pump looms.
Old Feb 18, 2016 | 02:55 PM
Loomer's Avatar
Loomer
Plus one to the above!
Old Feb 18, 2016 | 08:44 PM
martysmartie's Avatar
martysmartie
Exactly, in the case of the fuel pump it can lead to a melt down.
Even know you may have got it running, it's still old wiring and should be rewired.
Martin
sridgett
48
Feb 20, 2016 09:56 AM
mjonathan24
Feb 18, 2016 05:52 AM
fordfocusmk1
Feb 14, 2016 06:31 PM
Eigdoog
Feb 13, 2016 02:22 PM
fordsteve77
Escort MK 5 / MK 6
Feb 12, 2016 07:51 PM
