ST170 Timing Cam Belt Tensioners KNOWLEDGE NEEDED.
Old Feb 10, 2016 | 11:58 AM
fakejimmymorgan's Avatar
fakejimmymorgan
Default ST170 Timing Cam Belt Tensioners KNOWLEDGE NEEDED.
Have just bought an 03 ST170 (limited number in oz) every guide I read (including the ford one) says that the timing belt kit is the same as the stock 2.0 Zebec. So I went and spent $150 and bought one.
Now everyone (on the ST Facebook page) tells me the tensioner is too "big" and won't be right. To save hundreds in garage fees and having a mechanic tell me to come back when I have the right parts I've ordered the "right" part from the UK for $198.
What is so different about the tensioners? How different can they really be? every one of them that I'c checked out for the ford is identical in the listed dimensions. 8mm bore 60mm diameter and 48mm overall depth.
Please hit me with what you know (especially of you used an aftermarket kit). There is no ford Dealer within 200kms of my city and the nearest dealer told me the part is no longer being made. I gave them the UK number and it didn't correspond to anything in Australia 2M5V6K254AA was the aussie number I was given for the exclusive tensioner.
I appreciate all your help.
Jimmy
Old Feb 10, 2016 | 02:56 PM
STeve's Avatar
Super Moderator
biggest issues with outside uk purchases is the middle men who all claim to know whats what, heres links to uk suppliers showing part numbers if it helps
http://www.fordpartsuk.com/shop/ford..._f_1145749.htm
or whole kit on ebay which also shows part numbers
http://www.ebay.co.uk/itm/Genuine-Fo...gAAOxyWt5SZmJy
and with idler wheel
http://www.ebay.co.uk/itm/Genuine-Fo...IAAOxyoahSZmOF
Old Feb 10, 2016 | 10:15 PM
fakejimmymorgan
Thanks 1-PD I actually bought one from fordpartsuk yesterday. Hope it will arrive before the 26th. Will definitely be measuring the UK one to try and grasp exactly what is different about it. People seem to say too big but I have no idea in which way its too big.
Old Feb 11, 2016 | 02:54 AM
fakejimmymorgan
Heres some dimensions of the one Ford told me will work but is no longer produced.
Old Feb 11, 2016 | 03:11 AM
fakejimmymorgan
So the UK and OZ numbers seem to add up, they're the same unit but not brought to Australia anymore. They seem to have been used on other fords and mazdas and some of those have compatible part numbers also. The tensioners may look the same in the flesh but these are a list of tensioners that are not ZETEC ones apparently but would be interchangeable with the OZ/UK part numbered ones.
Old Mar 1, 2016 | 08:45 AM
fakejimmymorgan
Default Found the difference!!!
Firstly the bodies are constructed differently. The ST has an offset bore for the bolt whereas the Zetec one is more centralised. The amount of turn they can develop in order to tension the belt is also different. Finally the indexing lug on the Zetec tensioner is different to the ST so even though it has the same overall dimensions it just plain wont fit. pictures to follow
Old Apr 6, 2016 | 01:12 AM
fakejimmymorgan
James Porter
14
Feb 11, 2016 02:09 AM
Ford Focus ST Parts for Sale
Feb 10, 2016 10:00 AM
155lee
Feb 9, 2016 01:01 PM
Ak47mh
Feb 8, 2016 10:00 AM
Pinchers-ST
Feb 4, 2016 07:20 PM
