cosworth thermostat area corroded on head?? fix??
Old Feb 2, 2016 | 08:08 AM
lockie's Avatar
lockie
Default cosworth thermostat area corroded on head?? fix??
my cosworth 2wd head is corroded/pitted where the thermostat housing buts up against it
im now using the 4wd thermostat housing on this so it only seals on an o-ring
my concern is this will leak, any ideas on a repair while the head is bolted on???
I was thinking of using a 2wd gasket but it doesn't have much of a mating surface on the 4wd stat housing?
Old Feb 2, 2016 | 08:29 AM
haz87's Avatar
haz87
A skim of chemical metal to fill in the pitting should work (as long as surfaces are mega clean beforehand).
Ultimately weld and skim will be required for a more permanent fix - but appreciate this isnt going to be do-able with the head in place.
Old Feb 2, 2016 | 08:31 AM
lockie's Avatar
lockie
exactly what I was thinking
Old Feb 2, 2016 | 12:56 PM
Gazzonator's Avatar
Gazzonator
Gary Krishna
Got this exact problem myself.
I've given my spare thermostat housing to my mate to fill in the recess where the o ring sits with weld and then skim it flat. Hopefully then I should be able to use a gasket.
Old Feb 2, 2016 | 12:59 PM
stevieturbo's Avatar
stevieturbo
C**t
Plenty of sealers about for all sorts of things.
Stat housing on my Isuzu 1.7td just bolts up dry to the iron block. ie no gasket, just sealer and it's a pretty shitty surface !
I'm amazed it doesnt leak ( well it did eventually but just needed to clean and re-seal it )
Old Feb 2, 2016 | 01:21 PM
Turbosystems's Avatar
Turbosystems
Super Moderator
Tiger seal just fixed the tumble dryer door handle with it, only problem you'll have is removing it at a later date
Old Feb 2, 2016 | 01:27 PM
stevieturbo
C**t
Doubt tigerseal would be rated for engine temperatures though.
Plenty of Loctite sealants rated for high temperature and with good gap filling abilities.
http://www.loctite.co.uk/gasketing-9224.htm
Old Feb 2, 2016 | 01:41 PM
ajamesc's Avatar
ajamesc
cossie fan (unluckerly)
Chemical metal will fill the pits just fine
3FRD
38
Mar 17, 2016 09:56 PM
155lee
Feb 25, 2016 09:02 PM
siscossie
15
Feb 21, 2016 05:34 AM
Big-al-1978
Feb 6, 2016 11:24 PM
Mungus
Feb 2, 2016 09:27 AM
