Dump Valve Advise
Old Jan 27, 2016 | 05:27 PM
timsrs's Avatar
timsrs
Default Dump Valve Advise
Hi Guys
I am running a Harvey Gibbs 380bhp engine...
T34.48
Siemens 55 Lb injectors etc...
At the moment i have no dump valve and get ALOT of chatter when i come off the accelerator.
What dump valve is best for the YB, i am not after a loud whoooooosh noise either.
Any advise on whats best to buy.
Thanks Guys
Old Jan 27, 2016 | 05:43 PM
cossie330's Avatar
cossie330
I've got the group A spec r one on mine
Old Jan 27, 2016 | 06:39 PM
siscossie's Avatar
siscossie
3-door moonstone
Im running nearly same spec and the group A is fine on mine good sound too
Old Jan 27, 2016 | 07:56 PM
martysmartie's Avatar
martysmartie
You need a recirculating type, as you don't want the noise.
Martin
Old Jan 31, 2016 | 10:07 AM
turbotrev's Avatar
turbotrev
Am I right in saying the spec-r ones are very similar to the Grahame Goode ones as in they both have a diaphragm and filters on them?
I currently have an msd twin piston one but I want something really loud ����
Cheers Paul
Old Feb 6, 2016 | 08:24 AM
cossynut2's Avatar
cossynut2
10 Year Member
Cheers Paul
Each to their own but why do you want a really loud dump valve ? Fine on a rally car but on a road car?
Old Feb 7, 2016 | 08:27 PM
turbotrev's Avatar
turbotrev
I just like the noise tbh.
The one I have fitted now I just don't like the sound of.
If I could remove it I would but I have a gt series turbo so have been advised to keep one fitted
Cheers Paul
Old Feb 7, 2016 | 10:54 PM
Mad_Mat's Avatar
Mad_Mat
New Owner
My 3dr has a bailey dump valve.
It's noisy and I quite like it tbh.
Old Feb 8, 2016 | 07:31 AM
cossynut2's Avatar
cossynut2
10 Year Member
As I said if you like the dump valve noise its your choice, my 2wd has a 450bhp engine, goes like a rocket and has never had a dump valve. My ITG cone filter is inside a group A alloy air box and so chatter noise is hardly noticeable. I prefer the noise the engine makes without a dump valve but that is me.
Old Feb 8, 2016 | 12:41 PM
turbotrev's Avatar
turbotrev
If I could run my car without one I would, Turbo noise sounds the nuts.
The noiser the better for me.
I'm not keen on the noise the Bailey ones make.
Imo the diaphragm ones are better sounding than the piston ones...
Cheers Paul
Rs Gus
Apr 13, 2016 07:54 PM
Bart
Feb 23, 2016 08:57 PM
James Porter
Feb 7, 2016 04:37 PM
Murfyboy
Fiesta RS1800/RS Turbo
Jan 12, 2016 04:27 PM
beaver rs 88
Jan 12, 2016 01:41 PM
