Cosworth 2wd Engine
Got this engine for a project but a change of direction, it has had the head removed to see inside and put together to store.
It has been sat for a while, there is no sump but I have a Big wing sump modded for the mk2 escort that would be extra
So it will need a gasket set there is a new cambelt that will come with it
Price is £2750 ovno
205 block on standard bore
2wd head
2wd exhaust manifold and T3 turbo with uprated actuator looks like -31
2wd inlet manifold with standard fuel pressure reg
Blue injectors
Motorcraft water pump and pulley
Alternator
2wd thermostat housing
Throttle body with ISCV and TPS 09
Can send more pictures by email
Price is £2750 ovno
2wd head
Blue injectors
Alternator
youngben
Feb 19, 2016 05:35 AM
Tank Mike
Feb 2, 2016 10:10 PM
Mark RS
Alloy wheels and ICE for sale
Jan 7, 2016 08:18 AM
morg65
Escort Range
Jan 4, 2016 07:42 PM
