Ford Focus Range This Section Contains All The Ford Focus Model Specific Forums.
Ford focus 1.8 duratorq
Old Jan 26, 2016 | 11:35 AM
sambo170588's Avatar
sambo170588
Default Ford focus 1.8 duratorq
Hi people
Been a while since ive been on here back to a good old ford..and the problems��
Just had a headgasket water pump and belt done on my focus 1.8 duratorq diesel.. now the revs are rising when changing there gears..the higher revs the more it revs when the clutch is depressed��
Any suggestions? Theyve changed the clutch switch on the pedal.. now there saying could be a bad connection but it wasnt doing it atall before??
Theyve also bypassed my egr would this cause any problems?
Any help appreciated folks
Sam
Old Jan 28, 2016 | 06:20 PM
How high is it reving.
When the car is coasting and you have dipped the clutch where are the revs at.
Old Jan 29, 2016 | 08:47 PM
sambo170588
Just a little bit glen.. the mote i rev the more its revs.. for example in 3rd i change at 5k it revs 400 or 500 rpm soon as the clutch is depressrd.
Sam
Old Feb 3, 2016 | 08:53 PM
sambo170588
Bump anybody?
Old Feb 4, 2016 | 07:48 AM
My wifes mk1 focus 1.6 16v petrol does this matey.
When your coasting to a junction and dip the clutch the revs rise toll the car comes to a standstill.
Dean Guest
Ford Focus ST
Mar 8, 2016 08:36 AM
andyrst88
Feb 13, 2016 03:47 PM
dannyboysean
12
Jan 3, 2016 08:16 PM
FlashLam123
Ford Focus Diesel
Dec 29, 2015 02:07 PM
GHIA
Ford Focus Range
Dec 28, 2015 10:52 AM
