Cosowrth 2WD compression test
Old Jan 23, 2016 | 10:54 AM
SGP's Avatar
SGP
10 Year Member
Default Cosowrth 2WD compression test
cossie is showing 100 on two cylinders and 120 on the other two should be 140 + so not good ..
- anyone knows what's wrong with the engine ?
Piston ring gone or head gasket needs replacement ?
Any idea what it would cost to get it repaired ?
Car is now in Kent and Road registered .
Best
Old Jan 24, 2016 | 01:32 PM
dissmalrs's Avatar
dissmalrs
you can check if it rings or head by putting some (small amount ) clean oil in through the spark plug hole and re test the compression
if the compression goes up it will be an issue with the rings/ bore if you ge no change it will be head/valves
it wont tell you exactly but it will narrow your search down
Old Jan 25, 2016 | 07:29 AM
SGP's Avatar
SGP
10 Year Member
It's with the Mechanic now and all I did was a compression test.
They asked whether I wants to open the engine and see what's wrong or sell its as it is . Decided to fix and make sure the car is running right as it's an amazing looking car.
Has Ap brakes , lots of RS500 parts . Just need a good person to get it running right
Old Jan 25, 2016 | 12:46 PM
SGP's Avatar
SGP
10 Year Member
Not sure how to tell whether it's a 205 block
Old Jan 25, 2016 | 02:28 PM
Sierrasideways's Avatar
Sierrasideways
205 is written in big letters on the side of the block...or 200 if it is indeed a 200 block.
Old Jan 25, 2016 | 02:35 PM
SGP's Avatar
SGP
10 Year Member
Okok, would check with the mechanic .
Hopefully I would know an answer today .
Old Jan 26, 2016 | 06:39 AM
SGP's Avatar
SGP
10 Year Member
Mechanic is only opening the head on Friday.
Damn
harvcore
Jan 21, 2016 08:52 PM
Shaunc
Escort Range
Jan 20, 2016 06:38 PM
fordfoci
Jan 18, 2016 07:10 PM
cossie330
Jan 17, 2016 09:52 AM
