Speedo problem or 1.4 ECU to 1.6 motor
Hi, I changed the Fiesta MK6 engine from 1.4 to 1.6 (petrol). I haven't got ABS and the 1.6 ECU requires it. For this reason, my speedometer is not working. VSS is in the gearbox, but the 1.6 ECU does not communicate with the VSS signal . Is it possible to solve this problem without installing ABS? Or will operate 1.4 ECU to 1.6 engine?
kevin micallef
Dec 27, 2015 02:13 PM
liamT74
Dec 24, 2015 05:48 PM
