here we go again.. hot S2.. problem maybe solved?
Old Apr 6, 2005 | 04:53 PM
RS-adam's Avatar
RS-adam
Default here we go again.. hot S2.. problem maybe solved?
I've been told, that if you have a problem wit your RST running hot, you should change the thermostat and the thermo timeswiths to those from a cossie????
can some conferm this??
Old Apr 6, 2005 | 05:01 PM
rs_daz's Avatar
rs_daz
yeh ive done this as i have a grs up front the cossie stat opens at 82 i think and the standard one at 88..
mine still runs hot....and i found out the fans are the wrong way so its sucking hot air though the rad to the front
Old Apr 6, 2005 | 06:48 PM
vroooom ptssssh's Avatar
vroooom ptssssh
It Wasnt Me!
also check header cap isnt leaking ive got an XR2 fan switch an the fun cuts in right on the quarter mark
Old Apr 6, 2005 | 07:28 PM
cooler king's Avatar
cooler king
my rst is at the moment fairly standard but id like to uprate the cooling before i do much more to the engine, whats the best way for me to do this and for me to be able to use myself!?
Old Apr 6, 2005 | 07:43 PM
Vin Diesel's Avatar
Vin Diesel
I have had my thermo remove so it runs cool. will have to put it back when winter comes tho
Old Apr 6, 2005 | 08:18 PM
RS-adam's Avatar
RS-adam
rs_daz: nice one mate..... LOOOOL
vroooom ptssssh: my old header cap was leaking... so now im waiting for a bailey headertank I think I will buy a XR2 fan switch tomorrow.. sounds very good.... tanx mate
Old Apr 6, 2005 | 09:02 PM
L33 BYT's Avatar
L33 BYT
Sounds really silly but I think really important. I had this problem when I was running a GRS. do you know what I needed to do. Change the Rad. I thought mine was ok but I bought a new one and never had another problem.
Old Apr 6, 2005 | 09:24 PM
glenis's Avatar
glenis
VRRROOOOOOOOOM
is an XR2 fan switch the same as the 4x4 cosworth one that i have just bought !?
Old Apr 7, 2005 | 02:14 AM
wildheart's Avatar
wildheart
Could also be a lazy water pump or headgasket trouble
Old Apr 7, 2005 | 08:25 AM
andre_k's Avatar
andre_k
i have similar probs, my rst gets hot real quick in town, sometimes even gettin up to the 'n' of norm. then she takes ages to cool down when i start driving at 30 mph. on the other hand, i took her for the 1st time on the m1 and the temp gauge was REAL low, it was literally 1mm below the very first marking on the gauge
i have changed the fan switch for a new one (wasnt cutting in till near top of gauge) but it hasnt helped a great deal , cuts in a lil earlier but not a lot.... this xr2 one sounds good, may have to invest lol1
Old Apr 7, 2005 | 08:53 AM
AKRS1's Avatar
AKRS1
it would be low on the m1 bcos your blasting it down the motorway so you would get cool air into your engine bay. Fan dont usually come on when your driving down the motorway. Ideally your fan should come on when the temperature guage is on half
Old Apr 7, 2005 | 05:25 PM
RS_JAY's Avatar
RS_JAY
Spot on!
Old Apr 7, 2005 | 08:27 PM
adamS2RST's Avatar
adamS2RST
As he said
Old Apr 8, 2005 | 12:15 PM
RS-adam's Avatar
RS-adam
I tjecked wit my local ford dealer.... and the XR2 fan switch was soposed to be the same at the one that already are in a RST
Old Apr 8, 2005 | 12:35 PM
glenis's Avatar
glenis
get a COSWORTH 4x4 FAN SWITCH THEN !!
ITS RED NOT ORANGE
Old Apr 8, 2005 | 08:45 PM
Hansenturbo's Avatar
Hansenturbo
ITS RED NOT ORANGE
this is what i told rs adam but i couldn`t rember from what cossie to take the fan switch from
problem solved then
Old Apr 9, 2005 | 10:27 AM
GrimmeRS2K's Avatar
GrimmeRS2K
if its running more than half way on the gauge u have a problem somewhere, unless u have a grs i/c that is!.
ive got a grs, low temp thermostat, heat wrap everywhere,water wetter in coolant and mine never goes above the half way mark with twin fans
Old Apr 9, 2005 | 10:44 AM
glenis's Avatar
glenis
grimmeRST, check that other thread please ?
about ZVH cold starting probs....
DAZZER
Sep 30, 2015 08:43 PM
DavidK
Sep 27, 2015 02:55 PM
Russ Payne
Sep 25, 2015 08:29 PM
