S2 mfi won't idle?!
Old Jan 16, 2016 | 05:10 PM
cortina41-2008's Avatar
cortina41-2008
Default S2 mfi won't idle?!
So, after doing the clutch on my s2, everything refitted. Goes to start it and it won't idle. Checked everything, all plugs ok etc. It does start, but just won't idle, I'm having to blip the throttle so that it doesn't stall. Any ideas? Cheers
Old Jan 16, 2016 | 05:43 PM
xrmalin's Avatar
xrmalin
Check all your boost hose clips are nice & tight & it sounds like you've got an air leak if your still running the standard mfi fueling system
Old Jan 16, 2016 | 06:18 PM
studabear's Avatar
studabear
Years ago I did this on my S1, I had knocked the breather off that attaches to the metering unit, the turbo doctor spotted it in seconds.
Old Jan 17, 2016 | 01:20 PM
Chas's Avatar
Chas
What this man said .
MFI is sensitive to vacuum leaks. That hose is one to check as is even an iffy oil breather cap. Which breather system are you running?
Old Jan 18, 2016 | 03:34 PM
cortina41-2008
Running standard system. Noticed that there isn't a vacuum pipe going to the pressure regulator. Where should this come from?
Old Jan 19, 2016 | 01:00 PM
Piston Broke's Avatar
Piston Broke
pressure regs dont have one mate
Old Jan 19, 2016 | 02:37 PM
cortina41-2008
So what is that pipe/port on the pressure Reg? I'm sure I've seen a pipe of some sort attached to it on previous erst's I've owned before
Old Jan 19, 2016 | 03:09 PM
Nosmonkey's Avatar
Nosmonkey
Some people used to hook it up to the inlet as a crude rising rate fuel pressure reg afaik.
I had same problem as you, wasn't idle unless i nudged the throttle, boost pipe was loose.
Old Jan 19, 2016 | 04:06 PM
cortina41-2008
Something I didn't mention, after doing the clutch, I fitted a large front mount replacing the standard one. Would this of caused it in any way?!
Old Jan 19, 2016 | 05:32 PM
xrmalin's Avatar
xrmalin
The intercooler itself shouldn't but if the boost hoses haven't be tightened up properly that'll be your air leak causing the car to cut out
Old Jan 19, 2016 | 05:49 PM
studabear's Avatar
studabear
Was the intercooler new, could it have a leak? That's if all your hoses are tight etc.
Old Jan 19, 2016 | 07:49 PM
cortina41-2008
Yea it's a brand new airtec so should be ok. I'll have to have a play with it at the weekend. I'll update if I find a solution
Old Mar 15, 2016 | 04:10 PM
cortina41-2008
Update - fitted other metering unit, started straight up and runs well
youngben
Feb 19, 2016 05:35 AM
andyrst88
Feb 13, 2016 03:47 PM
Murfyboy
Fiesta RS1800/RS Turbo
Jan 12, 2016 04:27 PM
Antony Mann
Escort Range
Jan 8, 2016 05:23 PM
Antony Mann
Escort MK 5 / MK 6
Jan 7, 2016 10:33 PM
