Type 9 fitting Sequential onto Cosworth YB
Old Jan 11, 2016 | 09:10 AM
Benzo25's Avatar
Benzo25
Default Type 9 fitting Sequential onto Cosworth YB
Hi guys,
This is my 1st post, hope you fellas can help me. I've a type 9 fitting sequential to install on behind my YB.
If I use a Pinto / Cossie to type9 bellhousing, what flywheel should I use? And what starter?
I need to use a 7.25" race clutch to.
Who can supply me with the parts? What do the guys use that are running elites & quaife boxes?
Thanks in advance. Iain
Old Jan 11, 2016 | 11:47 AM
Blades Rally Team's Avatar
Blades Rally Team
Hi Mate
Is the YB normally aspirated or Turbo?
If it's Turbo I don't think the Type 9 will stand the power I am using a Romain Opplinger Sequential Box built into a MT75 casing done a couple of events and seems quite good upto now at 300+bhp and 440lbs/ft
Old Jan 11, 2016 | 12:08 PM
Benzo25's Avatar
Benzo25
Originally Posted by Blades Rally Team
Hi Mate
Hi mate, it's a type9 fitting tractive RD906 going onto a 500hp YB Turbo.
jessie_rs
11
Apr 27, 2016 03:04 PM
andyrst88
Feb 13, 2016 03:47 PM
leedsrhinos126
Jan 23, 2016 10:18 AM
Fordmad!
Jan 8, 2016 05:48 PM
eddyj
Jan 7, 2016 10:26 PM
