Fitted new stereo into Saph. Blown something
Old Jan 5, 2016 | 09:07 PM
leedsrhinos126's Avatar
leedsrhinos126
Default Fitted new stereo into Saph. Blown something
I fitted a brand new DAB stereo the other day, it worked perfectly until i cranked the volume to full which resulted in interior parts not working.
Stereo, central locking, clock and roof lights don't work. All other components work fine. No fuses are blown and earths are fine as well.
Any ideas please before i have to call an electrician out.
Old Jan 6, 2016 | 05:40 PM
Sounds like its draining power from the other parts.
Have you tried a permanent live straight from the battery. Also give it a good earth too.
Old Jan 7, 2016 | 10:14 AM
slammedorion's Avatar
slammedorion
Upgrade wiring as Glenn said
Old Jan 7, 2016 | 05:35 PM
leedsrhinos126
Even with the new stereo not connected the central locking etc still don't work.
Old Jan 7, 2016 | 08:05 PM
trigger-'s Avatar
trigger-
Have you checked the relays?
Old Jan 17, 2016 | 05:52 PM
martysmartie's Avatar
martysmartie
You have blown the fuse, it's 20A.
Martin
Old Jan 18, 2016 | 06:53 PM
leedsrhinos126
Martin
I've had all the fuses in the fuse box out to check each one, they are all fine.
Also noticed that when i flash full beam only the n/s works. People keep suggesting an earthing problem but no cigar so far.
Thanks. wish it was just a fuse
Old Jan 23, 2016 | 10:18 AM
martysmartie
I know you mentioned it, but it would have made sense. That fuse protects the radio and everything else you mention.
Maybe check you have power at the fuse terminal?
Martin
massivewangers
Feb 8, 2016 01:51 PM
eddyj
Jan 4, 2016 07:30 PM
theheap
20
Jan 4, 2016 04:56 PM
cossie330
Jan 3, 2016 03:18 PM
burnzy
Jan 2, 2016 07:02 AM
