Rs turbo heater packed in
Old Jan 5, 2016 | 07:39 PM
davidfordrs's Avatar
davidfordrs
Default Rs turbo heater packed in
After a bit of help if possible, my heater has stopped working in my s2, was working fine then parked up went back out and nothing, well there is a very small amount of hot air comes out but it is very little but the heater blower isn't coming on at all, any ideas what could cause it, the car is converted to efi incase that makes any difference, cheers
Old Jan 5, 2016 | 09:06 PM
Scott_Rst's Avatar
Scott_Rst
so its just the blower itself thats doing nothing? check fuses/old wiring etc, put 12v direct to motor and see if it spins up,, or if you have another blower handy just swap it to see?
I've went through a couple of heater blowers that have just given up!
good luck!
Old Jan 8, 2016 | 03:59 PM
johnboy73's Avatar
johnboy73
i had a similar problem with mine and it turned out the fuse itself wasnt seating properly and was loose,i just pinched the holder a little bit and all sorted.
Old Jan 10, 2016 | 02:56 PM
davidfordrs
Thanks johnboy73 that was exactly what was wrong lol, all fixed now
Old Jan 10, 2016 | 03:06 PM
johnboy73's Avatar
johnboy73
No problem mate,glad I could help!
dojj
15
Sep 5, 2020 07:19 PM
martinabella
22
Jan 25, 2016 02:42 PM
DixieTheKid
Dec 31, 2015 01:54 PM
rsturbolee
Dec 15, 2015 03:28 PM
