What are these brakes??
Old Dec 19, 2015 | 08:24 AM
Prince_Thain's Avatar
Prince_Thain
Default What are these brakes??
Rears: (also, what's the metal bit that looks welded on is it a spacer?
http://s12.postimg.org/9szbjc4oc/IMG...219_091414.jpg
Fronts:
http://s29.postimg.org/hxvhs9gty/IMG...219_091553.jpg
Thanks in advance!
Old Dec 19, 2015 | 10:18 PM
stevieturbo's Avatar
stevieturbo
C**t
And any particular car they're fitted to ?
And no idea what you're referring to as welded on or a spacer.
Sure you've got the right photo ?
Old Dec 20, 2015 | 06:59 AM
Prince_Thain
Yeah I took these of a mk5 escort myself and wasn't sure which brakes they are. Any way of finding out?
The rears I think may be rs2k and possibly the front too, but wanted to know for definite do I can buy the right pads etc so any help would be great.
Old Dec 20, 2015 | 07:12 AM
Prince_Thain
Scottybo from escort evo said:
Rear ones are rs2000 brakes
Front ones look like mk2 mondeo 260mm
Old Dec 20, 2015 | 09:02 AM
jamie's's Avatar
jamie's
Rears are mk5 escort rs2000
Fronts look like many differant cars, without some measurements it would just be a guess
They look like rs2000 brakes as well but they could be bigger?
Old Dec 20, 2015 | 09:18 AM
focusv8's Avatar
focusv8
Use this site to check pad sizes;
http://www.apecbraking.co.uk/catalogue/size
Old Dec 20, 2015 | 09:33 AM
stevieturbo
C**t
Remove pads, look at them, select correct ones. There may still be visible part numbers on the pads
You can search here by dimensions, vehicle etc etc
Sp3no
Dec 14, 2015 09:20 AM
xr2mk2turbo
Nov 27, 2015 10:37 AM
Ridgey
51
Nov 14, 2015 07:49 AM
rallycross
Nov 11, 2015 02:37 PM
