mk1 frs oil return thread size
Old Dec 8, 2015 | 01:01 PM
kingbx95's Avatar
kingbx95
Default mk1 frs oil return thread size
Hi
Building up my engine and don't have the original push fitting. I want to aeroquip the oil return from t34 to the original location but I need to know the thread size to either buy or make somthing up to suit.
Can anyone help please?
Old Dec 8, 2015 | 01:08 PM
dodge8283's Avatar
dodge8283
Its not threaded bud.
Old Dec 8, 2015 | 02:21 PM
thielt1's Avatar
thielt1
PM Sent
Old Dec 8, 2015 | 02:35 PM
kingbx95's Avatar
kingbx95
That's really odd. My engine had been dry built by someone else before I had it and where the return normally is has been ground back a bit as the guys manifold fouled it, he apparently was going to block it off and put the return into the sump. So I have no push fitting by there is threads in the hole that's left? So confused. I'm going to have to try and find somthing to fit lol
Old Dec 13, 2015 | 11:00 AM
JamboRS's Avatar
JamboRS
focus rs 1672
It is threaded. If you look in the hole where the return goes its threaded
The thread is a weird size mate
Think its around m16x2.0 or 5/8 12tpi bsw
Other option is to get an engine adaptor from carpartsexpress and thread the side your aeroquipping and use the std o ring on block side
Old Dec 13, 2015 | 11:46 AM
kingbx95's Avatar
kingbx95
Thanks alot for that mate. I'll have to investigate further I think but that's a good starting point. Do you know what the standard block side fitting is? My problem with that is I don't have the original fitting with the egg shaped plate that fixes to the block
Old Dec 15, 2015 | 04:30 PM
JamboRS's Avatar
JamboRS
focus rs 1672
You need one of these
You can then make the horseshoe bracket from some metal to hold it in place
Heres an oil return i made for myself
Old Dec 15, 2015 | 05:11 PM
kingbx95's Avatar
kingbx95
Can you buy that fitting or did you machine it. I have a small watchmaking lathe so that's not a problem if I had dimensions
Thanks for the help mate
Old Dec 15, 2015 | 07:40 PM
JamboRS's Avatar
JamboRS
focus rs 1672
Ill pm you mate
cpur
Feb 22, 2016 06:44 PM
minky
Jan 30, 2016 11:23 PM
Sp3no
Dec 8, 2015 09:03 AM
Forsale
Dec 6, 2015 03:56 PM
4x4kiwi
Nov 26, 2015 02:54 AM
