Thrust bearing help
Old Nov 27, 2015 | 06:21 PM
jay030787's Avatar
jay030787
Default Thrust bearing help
What's people's thought on what will do this to my thrusts it was only rebuilt less than 2000 miles ago
Old Nov 27, 2015 | 08:37 PM
Tim Wharton's Avatar
Tim Wharton
Not enough end float in the first place most likly
Riding the clutch-no
Semi siezed clutch cable holding clutch on load slightly or clutch ratchet not releasing when foot off pedal
Cheers Tim
Old Nov 27, 2015 | 08:45 PM
jay030787's Avatar
jay030787
If it was end float it would be both sides wouldn't it and nothing wrong with the clutch system at all it's also sized the cam in the head could that pull it over on one thrust the crank trying to turn the sized cam
Old Nov 28, 2015 | 07:47 AM
Tim Wharton
If the cam has siezed in the head it sounds like you have oil supply problems did you have good oil pressure before it failed
Old Nov 28, 2015 | 08:18 AM
jay030787's Avatar
jay030787
When it was cold it was at 5 bar when ref hot it was at just under a bar but just after I got it back from the rebuild it suffered with oil pressure I found out it was the pressure release valve sticking just don't see why it killed one side thrust
Old Nov 28, 2015 | 04:34 PM
Tim Wharton
If it was the thrust at the rear of the engine which had more damage it is because the rear one has load on it when the clutch is applied .
So if the oil pressure was low it will always be the rear which recives more damage.
As a matter of interest who supplied your oil pump.
Old Nov 28, 2015 | 05:32 PM
jay030787's Avatar
jay030787
Or right thanks for that and it was a burton high pressure pump so don't no what to go for next
Old Nov 28, 2015 | 08:39 PM
Roscopeco's Avatar
Roscopeco
P8 Managed S1 with ALS
I bought a burton high pressure pump for mine when my engine was built as couldn't find a genuine oil pump . I eventually found a genuine pump so changed it before the engine was fired for the first time .
Since then iveheard a few people say they had burton pumps and they failed .
Genuine cvh pumps whether it be for s1 or s2 cranks are like rocking horse shit to get hold of these days sadly
Old Nov 28, 2015 | 10:17 PM
jay030787's Avatar
jay030787
Yes this is my second to go now where did you find a genuine oil pump
Old Nov 28, 2015 | 10:42 PM
Roscopeco's Avatar
Roscopeco
I got mine from Graham at Carparts Express who got it from German supplier and that was nearly 4 years ago .
Old Nov 29, 2015 | 09:11 AM
russ rs's Avatar
russ rs
I had a dealership principle trying to get me and original one. They can't find any stock anywhere
Old Nov 29, 2015 | 09:17 AM
jay030787's Avatar
jay030787
I no so am stuck with what to get
Old Dec 1, 2015 | 08:19 AM
Si74's Avatar
Si74
i have a genuine one in the sealed bag and took umbrage at paying Ford 89 quid I think it was for it all those years ago.
This is meant for my spare engine but is probably worth more than the engine, crazy world of RS Turbos,lol
Old Dec 1, 2015 | 05:42 PM
jay030787's Avatar
jay030787
Lol anyone no where I can get one these days
little bram
Nov 13, 2015 08:44 PM
ian.gordon
Jul 1, 2004 10:44 PM
RSCossieGaz
22
Jan 18, 2004 10:31 AM
