4x4 Sapphire Cosworth... God knows!!
Old Apr 5, 2005 | 09:10 PM
Spinza's Avatar
Spinza
Default 4x4 Sapphire Cosworth... God knows!!
I have this what i can only describe as a misfire. The car when driving normally... 2-3k revs seems to jump like i have kangaroo pwtrol!!!
When i accelerate hard i sometimes get a bang and a puff of smoke (raw fuel?) from the exhaust. This does not always happen and sometimes the car is fine (not often i must admit)
these aside almost everytime i get high on boost 15-20 psi the car seems to be missing and holding back. Please help, i have had the plugs out and they look ok.
the car is running 21psi max on dark greens with a 330 bayjoo chip.
Old Apr 6, 2005 | 02:38 PM
killerscum01's Avatar
killerscum01
Hi, Try your rotor arm I've had similar problems on most of my cossie's. Also check your plug gaps (very important on these cars).
Hope this helps.
Old Apr 6, 2005 | 09:15 PM
supatune's Avatar
supatune
yeah first thing i'd look at are plugs try setting the gap to 0.7 mm and make sure you're using good quality ones i know of a few detonations on top speed runs on slightly worn plugs and we dont want that !
Old Apr 7, 2005 | 07:52 AM
Spinza's Avatar
Spinza
Ill check rotor arm today. I have had the plugs out and they looked ok but i must admit i didnt check the gaps . The plugs are NGK9's
CheeRS for the suggestions guys
Old Apr 7, 2005 | 09:57 AM
wimwerf's Avatar
wimwerf
also check your coil....maybe go for an group A coil (there cheap)
clean and fasten (real good)the connectors on the bulkhead....back/above the engine....these are a nightmare on 4wd saph...
close the gap even further to 6.5mm.....(but 0.7 first.. )
good luck
Old Apr 7, 2005 | 10:38 AM
Rs1's Avatar
Rs1
Aye first i would close the gaps and as above check the earths,clean em and refasten. It does sound very similiar to overboost though,have you increased the boost latly?
Old Apr 7, 2005 | 03:30 PM
Spinza's Avatar
Spinza
Rotor arm and cap seem ok, i have cleaned em up a bit. I have also cleaned and used electrical contact grease on the connectors on the bulkhead (3 of em??) I will gap the plugs. When you say the earths you mean the earths on the coil??
Nov 1, 2015 06:53 PM
Rod-Tarry
75
Oct 13, 2015 04:44 PM
gcfcos
59
Oct 6, 2015 05:04 PM
Iain Mac
Sep 30, 2015 09:39 PM
Fil
Sep 30, 2015 12:08 PM
