Sticking accelerator
Old Nov 17, 2015 | 10:28 PM
Mondeo Les's Avatar
Mondeo Les
Default Sticking accelerator
I have a Ford Focus, 2002, CL, 1400 petrol.
Actually, it's not mine but a friends and I just fitted a new battery. When I drove it I realised the accelerator seems to stick. When driving, slowing down by talking your foot off the pedal doesn't quite do it as the revs stay up around 1500/2000RPM for a short while before dropping to normal tickover. Easy to rear end someone!
Testing at standstill the revs still hang high and lifting the pedal makes no difference so it's not 'connected'. I'm assuming there's no mechanical cable to lubricate so what could it be?
Old Dec 6, 2015 | 10:09 AM
stevieturbo's Avatar
stevieturbo
C**t
So what you're saying is the accelerator is not sticking and feels totally normal ?
But the engine does not drop to idle normally...so either an air leak somewhere or the idle control setup isnt working correctly.
It may simply need to re-learn after disconnecting the battery or you've disturbed or damaged something during that process.
Heitmann
Jun 1, 2020 11:39 PM
arkeye
Dec 13, 2015 09:56 PM
Tangodeltasierra3
Ford Focus ST
Nov 10, 2015 06:21 AM
Daviehastings
Ford Focus Diesel
Oct 24, 2015 10:59 PM
Ford Focus ST Parts for Sale
Oct 19, 2015 02:32 PM
