focus 2008 electrical problem
Old Nov 17, 2015 | 03:31 PM
tank1987's Avatar
tank1987
Default focus 2008 electrical problem
Ns light's are acting very strange started with dipped beam flashing bright then dull when I got out and looked indicator was stick on and dipped and side were on dimly only affecting ns, I'd I put main beam on all ns front lights go out except constant indicator front side and rear and fog lights won't work on either side at all
Old Nov 17, 2015 | 06:31 PM
chris cdti's Avatar
chris cdti
Checked the earths on the light units? And plugs in the Gem unit in the passenger foot well?
Old Nov 17, 2015 | 06:41 PM
H3lsing's Avatar
H3lsing
ffoc.co.uk
I would agree with checking the earths as they can get rusty over time. I would also change the relay for the lights, or you will be doing nothing but changing bulbs.
Old Nov 17, 2015 | 07:00 PM
RichieST's Avatar
RichieST
As said, check the earth point, pretty sure it's right underneath the headlamp unit. Not uncommon for the mk2 focus for them to corrode badly there. Also the headlamp multiplug might be wet inside if the seal is missing / damaged.
JoeyBoyden
Dec 17, 2015 09:07 PM
Mondeo Les
Nov 18, 2015 07:30 AM
eddyj
Nov 18, 2015 07:09 AM
fordsteve77
Nov 17, 2015 10:51 PM
Daveysaff
Nov 16, 2015 04:23 PM
