mk3 escort break upgrade help please
hi people iv got a standard mk3 escort 1983 or 1984
its all standard
apart from iv got a rs turbo engine fitted
but the brakes are still standard 1.3
need to upgrade then
but don't know where to start
need it to be a cheap upgrade lol no im asking loads now haven't got 1000s
can anyone help me
its all standard
can anyone help me
you could do a few things,, could just try get hold of standard rs turbo callipers and discs, or can do cosworth front conversion, theres a good "how to" guide at top of this section,
also just found this on eBay, you'd still need to get spacers etc for callipers (all listed in how to guide at top of this section)
http://www.ebay.co.uk/itm/Sierra-4x4...AAAOSwu-BWQJRP
all depends how far you wanna go i suppose, also some people might say to change to a bigger master cylinder/servo poss from a rs turbo or i think you can use a mk3 mondeo one but requires mods,, loads of info on this site about it though,,
cheers
cheers
I THINK a basic rs turbo set up would bolt straight on, but i dont know if base model hubs are same as rs turbo hubs for caliper mounting, if they are the same hubs then should just bolt on,,
The cosworth calipers in ebay link wont just bolt on i dont think, like i said for cosworth calipers the guide at top of page is spot on!
You can also do a 300mm brake upgrade using mondeo calipers etc,, but dont know anything about that, but heeeaps of stuff about it on here,
Scott
thanks people
mine is a 1984 by the way
you got a link scott to what your saying as stil trying to figure the forum out
A S2 Master and Servo should be fine seeing as both the Cosworth and S2 calipers use a 60mm piston. It's the disc and pads which are larger on the Cosworth items.
FWIW I understand Sierra Cosworth items are the only ones with fit without modifying. I know with mine the clearance was super tight ; I milled 1mm off the disc in the end as they did occasionally catch. They did not drag the car to a stop but the disc did occasionally brush the caliper.
thanks for all the advice people its much appreciated
what about if i use xr3i calipers and discs
was thinking the discs are vented on the xr3i i think
so if i buy some xr3i calipers and some good pads and disc's
will that be ok
will that be ok
Personally I'd go for the Cosworth setup all day long but I can appreciate it is not as cheap as it once was with disc/pad parts ( and I am not referring to buying cheap Chinese rubbish off eBay either).
If you are on a budget I'd look at the S2 RST setup. They should still be cheap and easy to obtain.
However, what engine do you have?
iv got a rs1600 turbo in a 1.3 mk3 escort on a budget as got a wife lol
looking for these cosworth calipers and all i keep finding is the rears
found the mk4 rs turbo calipers will thay fit
if i go down the s2 root are these the calipers i need
Check out this item I found on eBay: http://pages.ebay.com/link/?nav=item...937021&alt=web
stuck for now as cant drive it as wont stop lol gutted really can't wait to get it back on the road
backs are drums etc
was thinking about going st170 but using the st170 discsand calipers theres a fitting kit on line to use the st170 calipers
then its saying iv got to use minimum 16inch alloys
is that right
is that right
However, I have to ask why you would choose the Mondeo MkIII calipers over the Sierra items. I agree that they seem a little lighter but to limit your choice of wheels less does seem annoying.
It was probably the main reason I went with the Cossie 4WD items ; almost nothing fits behind the S1 wheels
Back to the OP AFAIK the ST170 discs fit with the MkIII Mondeo calipers but the hubs require redrilling and rethreading to take the larger bolts. I have not heard of the ST170 calipers fitting before. I understand that with the Mondeo/ST setup some 15" wheels may fit with the caliper being massaged but 16" is the smallest wheel that can generally fit without any issues.
This is a good example.
I don't know how small these standard brakes are but in my opinion you only need to upgrade brakes if you get faiding, have to give lots off pressure before lock up or can't lock up. I have upgraded to cosworth for myself aswell, but nowadays i wouldn't have done it again. Useless upgrade. Its my road car, it didn't faid, was able to luck up and pedal feel was ok. Putting that money in better tyres would have increased brake performance probably more
all sorted st170 calipers fitted great got the conversion kit of the net for 20 calipers cost 20 of a friend with discs and pads are buy new ones soon there do for now
only went with st as it was cheap
got a set of focus 4 stud alloys of Gumtree cheap there 16s so yer all in all with alloys calipers conversion kit was about 100..
didn't really wont to be grinding calipers down....
but my next thing is to upgrade the master cylinder what ones do you lot recommend do you think it needs doing or not mine is a standard 1.3..
