Escort Range Ford Escort RS1600i / Mk. 5 & 6 / XR3 Discussion.
ignition coil supressor whats it job how to test
Old Nov 15, 2015 | 05:23 PM
fordsteve77's Avatar
fordsteve77
Default ignition coil supressor whats it job how to test
What is the supressors job and how do you test?
I have uploaded photo of the part
There is 12 volts going into the suppressor from the green/red wire coming from - coil.
After suppressor out wire to speed sensor module/fuel pump relay there is only 0.29 ish volts coming from green/red
Attached Thumbnails ignition coil supressor whats it job how to test-20151115_163828.jpg
Old Nov 15, 2015 | 07:23 PM
martysmartie's Avatar
martysmartie
To prevent interference on the radio.
Martin
Old Nov 15, 2015 | 07:32 PM
fordsteve77
should the volts drop from 12 volts to 0.29 volts after passing through it?
Old Nov 16, 2015 | 09:30 PM
martysmartie
Probably, as it's only a small capacitor, essentially.
This would not cause running problems.
Martin
Old Nov 17, 2015 | 07:03 AM
fordsteve77
The coil green/red goes to suppresspr then from there to the speed sensor module then the fuel relay safety module then to the rpm rev counter, as my rev counter not working either....?
And the fuel pump relay aka safety module senses ignition pulses, and cuts the fuel supply if the ignition pulses stop
So where does it pick up ignition pulses.... anyone??
fordsteve77
Escort Range
Aug 19, 2022 05:48 PM
zsdom
Ford Focus (All Models)
Nov 15, 2015 09:11 AM
Wardy ZS
Nov 15, 2015 06:28 AM
morg65
Escort Range
Nov 13, 2015 02:09 PM
MattSPL
Nov 11, 2015 05:10 PM
