Need a -3 hose union
Anyone know for any uk companies that stock a male -3 AN to -3 AN female 45 degree swivel coupling fitting ?
Those I can find that do list them are listed as in the us or aus
ta
ta
Do you mean like this?
https://www.merlinmotorsport.co.uk/p...ing-g-6046-03p
Www.merlinmotorsport.co.uk
Or it might be dewits? That supply goodridge fittings. Send MK a pm as he might know, or MarkK might be able to help
Cheers, almost but this is the type am looking for but a -3 AN
https://www.merlinmotorsport.co.uk/p...ng-g-hl822-06d
This is the actual type I'm after to help reroute an oil feed pipe
http://www.getfast1.com/PPD-924103-1...ng_p_2980.html
Do you mean do awaynwith the silver part and the blue fitting and use a banjo?
That would work so long as you could get the correct thead to go in block.
I am far from an expert tho!
No doubt Earls will have them
http://www.earls.co.uk/earls/adapter...emalemale.html
You could do a 90 too, but you'd need a new fitting on the flexible hose too.
Rsturbo519
Nov 9, 2015 11:59 PM
