Lightning 2l flywheel when fitting to cvh
Hi guys as above do you lighten the 2l zetec flywheel when fitting to a cvh.
Need to know this as doing mtx conversion.
Engine Machinist
bit of an odd question... are you asking where the material can come off on the zetec flywheel specifically, or how the process works in general?
if you're asking the former, the best way is to take material off so it looks similar to this: http://www.dunnellengines.com/images...20Flywheel.jpg
you can also trim down the rear of the flywheel for a little more weight saving, but don't touch the trigger wheel if you intend to use it. it would also be best to get it balanced afterwards as it will probably be a fair way out after machining.
I don't need to worry about cps as I have trigger wheel on front off engine. ( crank pulley )
Steve Escos
02-04-2016 09:05 PM
Rsturbo519
08-11-2015 11:47 PM
