They'll both be 4 x 108 PCD so they'll fit onto the hub.
Might be a difference in offset, affecting how the wheel fits in the arch, but I can't see it being drastic
My missus has a 2008 Fiesta Zetec. She's thinking of buying a mk6 Fiesta (probably 2011/2012 model) but she wants to keep the alloys from the old car.
Will the wheels from a mk5 fit on a mk6? I know they're both 4-stud but is the spacing the same?
the mk6 starts at 2002 to 2005
then the mk6.5 went from 2005 to 2008
before the final face lift mk 6.75 in 2008
then the mk7 came along in 2008/9 and it's had a facelift in 2011 or so and then another one in 2012 and then again in 2014 and yet another in 2015
the mk4.5 is what you are refering to as the mk5 and those rims certainly don't fit without spacers etc
the later ones though have an offset of 51 or so, which means you simply need to find the offset of the car you are thinking of getting to see if they are interchangable
