Ford Focus Diesel This forum is for discussion of all things pertaining to the Ford Focus Diesel Range.
Pressure control valve
Old Nov 6, 2015 | 06:58 PM
Supercmaxer's Avatar
Supercmaxer
Default Pressure control valve
Good evening.
Please can someone help me lol,
I've searched the World Wide Web and have drawn a blank, I have a focus c max 2.0 tdci 2004. It's the Peugeot engine
I'm having problems with the anti shudder valve which closes when I switch of, basically it stops air getting in to the inlet. On my car there are two of the above valves. One operates the turbo and one does the vacuum for the anti shudder valve, I've replaced the valve but I'm getting no vacuum from it. There is power going to the valve as I've tested the plug and its 12v's.
Does anyone know or have the pipe diagram from these valves.
One of the pipes comes out of the turbo valve and connects to the one I have replaced which has vacuum coming from it, but there is nothing coming from the other one.
Anyone come across the same problem?
fordrallycar
Oct 11, 2015 12:55 PM
FlashRS
Oct 10, 2015 05:33 PM
PaulT
Oct 10, 2015 02:33 PM
anthony lea
Ford Focus (All Models)
Oct 10, 2015 01:43 AM
pieterjan
Ford Focus RS
Sep 17, 2015 06:17 PM
