Diesel bleed.
Old Nov 3, 2015 | 01:44 PM
henrydickens's Avatar
henrydickens
Default Diesel bleed.
How do I bleed the system on a 2006 fiesta 1.4 Diesel?
Old Nov 3, 2015 | 09:22 PM
CBenno's Avatar
CBenno
Should be a hand pump a black plastic bulb at the back of the engine bay by the air box
Old Nov 4, 2015 | 11:07 AM
henrydickens
Yep, been pumping that til my hand went numb, still no sign of it firing.
Old Nov 4, 2015 | 11:15 AM
henrydickens
What I want to know is, do I have to disconnect or loosen anything to let the air out whilst I'm pumping?
Old Nov 4, 2015 | 11:38 AM
gingeRS's Avatar
gingeRS
usually the pump will have a 1 way valve but im not 100%
Old Nov 4, 2015 | 02:52 PM
henrydickens
The full story is that I changed the starter. But a month lapsed between getting the old one off and fitting a replacement and all that while the front wheels were up on ramps. Now it turns over lovely but won't fire. I just assumed it was a fuel problem. What else could it be?
Old Nov 4, 2015 | 04:21 PM
mark826's Avatar
mark826
Blocked filter?
Old Nov 4, 2015 | 09:29 PM
CBenno's Avatar
CBenno
I would start with getting someone to plug it it to see how the land lies if there's no obvious faults stored check live data for engine speed and fuel pressure
Old Nov 5, 2015 | 07:36 AM
Hammerman21's Avatar
Hammerman21
Did you have any of the fuel system disconnected while changing the starter motor?
Old Nov 5, 2015 | 03:48 PM
henrydickens
None of the fuel system was touched when I changed the starter.
Old Nov 5, 2015 | 08:53 PM
Hammerman21
Ok.
It's possible without disconnecting any of the fuel system that the fuel has somehow ran back to the tank and you now have an air lock.
When you are pressing the bleeding bulb can you feel / hear fuel flowing through it?
Old Nov 5, 2015 | 09:03 PM
RichieST's Avatar
RichieST
Is the battery connected back up properly? What is the red immobiliser light doing? It should blink steadily with ign off, come on solid for a few secs with ign on, then go out.
Old Nov 6, 2015 | 01:34 PM
henrydickens
Immobiliser is doing what it should and I can feel fuel filling the pumper as I pump it.
Old Nov 6, 2015 | 06:57 PM
RichieST's Avatar
RichieST
Get a diagnostic check done on it. Could be anything really!
Old Nov 7, 2015 | 12:16 PM
Hammerman21
Is it attempting to start or just nothing?
Have you tried getting someone to pump the bleeding bulb when you're turning it over?
Old Nov 10, 2015 | 12:51 PM
henrydickens
It turns over but makes no attempt at firing. I had a guy come round and plug it in, no codes showed up and he had no idea why it wouldn't start. I'm at my wits end, this the first, and LAST diesel ford I ever buy.
Old Nov 10, 2015 | 06:52 PM
RichieST's Avatar
RichieST
It was running fine. You took it to bits, put it back together again and now it doesn't start. Doesn't sound like it is the car that is at fault here?
Old Nov 10, 2015 | 07:32 PM
Hammerman21
I sounds like you could have an airlock in the fuel system.
I know you've tried priming it with the bulb but for some reason that doesn't always work.
You could try the brake / clutch cleaner trick to see if it starts.
Spray small bursts of brake cleaner into the inlet manifold when trying to start the car, this often gets them to fire & start, if it starts keep it running to bleed any air from the fuel system.
Give it a go and see what happens.
Old Nov 10, 2015 | 08:29 PM
pcbp97's Avatar
pcbp97
is the starter motor turning the engine quick enough,because i know the focus 1.8 diesel wont fire the injectors unless the engine is cranking over fast enough.so it might be a duff starter or battery.
Old Nov 10, 2015 | 08:37 PM
RichieST's Avatar
RichieST
I wouldn't, the glow plugs can pre-ignite the brake cleaner, sending the charge back down through the intake or whatever!
Old Nov 10, 2015 | 10:34 PM
Hammerman21
You may get the odd backfire if you're unlucky, just make sure to keep your face out of the way.
Old Nov 12, 2015 | 12:06 PM
henrydickens
You're not wrong! Eventually had to strip it all down again to find a wayward plug that I must pulled out accidently, pushed it back in away she went. Still the worst car I have ever worked on tho.
Old Nov 12, 2015 | 08:51 PM
Hammerman21
At least you found the problem and it's running again and without losing your eyebrows
TeemuP
Nov 13, 2015 02:56 PM
Mark Baker
Nov 13, 2015 01:58 PM
paceo
16
Nov 11, 2015 04:19 AM
liamT74
Nov 2, 2015 12:13 PM
Botts
Oct 27, 2015 09:26 PM
